Solid rear mount
Old May 27, 2007 | 05:18 PM
Boner_Ben's Avatar
Default Solid rear mount
Anyone run a solid rear motor mount? My motor moves around alot with hasport mounts so I'm thinking either solid rear mount or get a metal insert made for the hasport, just wanted to see what others have done.
Old May 27, 2007 | 05:38 PM
cluelessmale's Avatar
Default Re: Solid rear mount (Boner_Ben)
chad (underpressure02) made all his own mounts, I can only find pics of the two side mounts, but the motor does not move.
Old May 27, 2007 | 05:53 PM
HybridKOOP's Avatar
Default Re: Solid rear mount (cluelessmale)
Holy vibration.
You could charge chicks to sit on the car while it idles.
Old May 28, 2007 | 06:41 AM
underpressure02's Avatar
Default Re: Solid rear mount (HybridKOOP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridKOOP &raquo;</TD></TR><TR><TD CLASS="quote">Holy vibration.
You could charge chicks to sit on the car while it idles.</TD></TR></TABLE>
It actually does not vibrate that much. I run solid mounts in my daily driver and it is not that bad. Dturbocivic also has solid mounts that is where I got my idea to make them. His look a lot nicer then mine since I was just learning how to weld when I made mine.
Old May 28, 2007 | 06:45 AM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boner_Ben &raquo;</TD></TR><TR><TD CLASS="quote">Anyone run a solid rear motor mount? My motor moves around alot with hasport mounts so I'm thinking either solid rear mount or get a metal insert made for the hasport, just wanted to see what others have done. </TD></TR></TABLE>
you are better off getting the 2 lower torque mounts solid. i belive avid racing makes billet ones, or if you know a machinest, or maybe have an hour or 2 of free time, you could build your own.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underpressure02 &raquo;</TD></TR><TR><TD CLASS="quote">
It actually does not vibrate that much. I run solid mounts in my daily driver and it is not that bad. </TD></TR></TABLE>
haha, its not that bad, but its worse than a set of hasports or something of that nature. my mirror used to shake all over the place with those suckers HAHA. on my racecar, thats a differant story. but honestly those solid mounts have no place on a "street" car
Old May 28, 2007 | 06:58 AM
Default Re: Solid rear mount (dturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">
but honestly those solid mounts have no place on a "street" car </TD></TR></TABLE>
Dave you getting soft on me? That is not what you said when you drove your "street car" to my house with solid mounts and the spool.
Old May 29, 2007 | 08:55 AM
dlcracing's Avatar
Hasport makes a solid insert for the rear mount, actually I think they make them for all of their mounts ... hit'em up
Old May 29, 2007 | 09:08 AM
whatVTEC's Avatar
I was running the jimfab lower torque mounts and that was plenty solid. But then again I wasn't making a ton of power
Old May 29, 2007 | 12:45 PM
0554's Avatar
i made my custon front lower mounts and run the jim fab rear mount. motor does not move
Old May 29, 2007 | 01:22 PM
DaveF's Avatar
Default Re: Solid rear mount (underpressure02)
Dave you getting soft on me? That is not what you said when you drove your "street car" to my house with solid mounts and the spool. </TD></TR></TABLE>
that was awhile ago. i also encourage drunk driving
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: (0554)
i used to run the JimFab . but im pretty sure they dont make them anymore?
Old May 29, 2007 | 03:21 PM
jasonp's Avatar
I took the rear stock one welded 2 plates and a piece of pipe to it to make it solid cuz of the hasports made mine motor shake alot.. I hope it does the job..
GK2
Jul 13, 2023 12:00 PM
acmoc
Mar 29, 2017 05:36 PM
preludeNApower
Jan 12, 2012 08:35 AM
Lsweez
Nov 6, 2007 11:22 AM
Maengelito
16
Dec 5, 2004 07:07 AM
