CRVTEC turbo R.C. 310 cc injectors, AEM FPR and rail, 10:1 FMU, inline MSD pump, VAFC..what is wrong
Old Dec 1, 2001 | 06:00 PM
1's Avatar
Default CRVTEC turbo R.C. 310 cc injectors, AEM FPR and rail, 10:1 FMU, inline MSD pump, VAFC..what is wrong
Why does this setup fall flat on its face when boost commences? Newbie here. I appreciate your opinions.
Old Dec 1, 2001 | 06:07 PM
TurboSedan's Avatar
New User
Default Re: CRVTEC turbo R.C. 310 cc injectors, AEM FPR and rail, 10:1 FMU, inline MSD pump, VAFC..what is w
I would say the 310cc injectors, try going to 440cc.
Old Dec 1, 2001 | 06:37 PM
Jared's Avatar
How much boost you running? What about your ignition timing? Got an a/f gauge?
Old Dec 2, 2001 | 07:35 AM
1's Avatar
Anyone else, before the thread disappears into cyber oblivion???
Old Dec 2, 2001 | 07:36 AM
JM Performance's Avatar
try answering our questions so we can answer yours.
Old Dec 2, 2001 | 07:43 AM
1's Avatar
Baseline 3-5 (anything higher forget it) pounds, timing at -16, hooking the a/f and egt gauges up today....sorry.
[Modified by 1, 8:46 AM 12/2/2001]
Old Dec 2, 2001 | 09:55 AM
b18cTurbo's Avatar
hey 1, i did ask you some question about your setup y you dont reply
com on man do some effort .
Old Dec 2, 2001 | 05:13 PM
1's Avatar
ttt
Old Dec 2, 2001 | 05:17 PM
jbsadler's Avatar
New User
With 310's you need an 8:1 FMU disk and what type of turbo setup are you running( which turbo, wastegate, sparkplugs, etc...)
Old Dec 2, 2001 | 05:23 PM
TurboInteg95's Avatar
man, I already told you it's the 10:1 disk, you need an 8:1.
Old Dec 2, 2001 | 05:30 PM
1's Avatar
NGK BCPR7ES-11, Drag kit with T04X turbo, TIAL wastegate....
Old Dec 2, 2001 | 05:46 PM
jbsadler's Avatar
New User
It's prob the 10:1 FMU disk....I bet it's feeding to much fuel when your boosting, causing it to run rich when you not.....
And be sure to gap your plugs to .32
[Modified by jbsadler, 2:47 AM 12/3/2001]
Old Dec 2, 2001 | 05:53 PM
1's Avatar
Do you think leaning it out with the VAFC as well would help? Or can that be done?
[Modified by 1, 6:54 PM 12/2/2001]
Old Dec 2, 2001 | 06:29 PM
jbsadler's Avatar
New User
I'm not sure...I'm non-vtec.......talk to integrated109....he has type-r turbo with 310's, 8:1 FMU, and VAFC......
Old Dec 2, 2001 | 09:08 PM
Turbolude's Avatar
When I had 310 inj. and a 8:1 fmu i was running really lean before vtec, after vtec i was still rich so i had to lean the fuel out with the vafc. I ended up using the 10:1 and just leaned the top end out and the low end was fine.
Old Dec 3, 2001 | 12:27 AM
liam821's Avatar
25 Year Member
timing at -16
try turning the timing back to normal. -16 it will run like ****. at 3-5psi boost you shouldnt need any ignition retard. I was running 12psi on pump gas with no ignition retard what-so-ever.
liam
Old Dec 8, 2001 | 05:08 PM
bodykit=rice's Avatar
umm he doesn't need a 8:1 that's crap...
laakea
Apr 3, 2006 07:13 PM
spoon95eg
Dec 19, 2005 06:15 PM
ityab0y
Jan 25, 2005 12:31 PM
xcivicdx
Mar 24, 2003 03:19 AM
hybridb18
Oct 7, 2002 10:04 PM
