Just Weighed in my R...
Old Dec 1, 2001 | 12:53 PM
ASNG's Avatar
New User
Default Just Weighed in my R...
Went to a local truck stop and with the swipe of my CC I was ready to roll onto the scale to get some numbers down...
In order, front wheels/all/rear wheels I got the following:
Front: 1609 lbs
Rear: 882 lbs
Total: 2491 lbs
This was on an empty tank with my rear seats and rear carpeting stripped out. I think there is about a 50 lb savings in the aftermarket exhaust as well. Full tank should add about 85 lbs over the rear axle.
Old Dec 1, 2001 | 01:08 PM
Flux's Avatar
Default Re: Just Weighed in my R... (ASNG)
I've got to go do that...
Old Dec 1, 2001 | 01:25 PM
Ibuprofen's Avatar
Default Re: Just Weighed in my R... (Flux)
how much does it cost to weigh a car?
Old Dec 1, 2001 | 01:26 PM
typerlover's Avatar
New User
Default Re: Just Weighed in my R... (ITYP3R)
That receipt shows 10 dollars
Old Dec 1, 2001 | 01:29 PM
Cyrio's Avatar
Default Re: Just Weighed in my R... (typerlover)
thats pretty cool.
Old Dec 1, 2001 | 02:37 PM
ASNG's Avatar
New User
It is not per car or per truck. For 10 bux canadian you get 10 measurements...I only used 4. It takes a measurement each time the weight changes and settles in at a steady value for a few seconds. For example when I roll on with the front wheels and I get out of the car once the weight settles in a few seconds it will take a read. I go back drive all the wheels on get out, it automatically takes another read and so on.
The system is designed to take automatic readings of the weight at each truck axle as the driver drives the truck/trailer combo over the scale. It is pretty cool and acurate to the pound!!
Old Dec 1, 2001 | 02:47 PM
GRM Scott's Avatar
25 Year Member
Here's mine: spare & jack out, 1/3 tank gas approx, otherwise basically stock
2520 if you have trouble reading
Old Dec 1, 2001 | 02:48 PM
Looose_R's Avatar
you guys dont have scales at your local racetrack that you can use for free? that seems odd, good weight numbers though!
Driven
11
Apr 18, 2007 10:32 AM
H.crx-si
Feb 10, 2005 06:50 PM
hondacivic4g
Dec 13, 2003 11:54 PM
MissMyHonda
May 16, 2003 09:13 PM
HX_Guy
10
Oct 1, 2001 02:10 AM
