Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
1990.
Old Apr 16, 2007 | 08:19 PM
Driven's Avatar
Default 1990.
got the CRX weighed...yep, 1990lbs... without a driver, full tank of gas.
Here's what contribute:
1990 crx hf (stock, it's like 1920lbs)
all interior, gone, sans dash with custom gauge layout, and two seats.
4 point autopower bolt in rollbar.
polycarbonite rear quarter panel windows
no front bumper support
CF hood
B18C1 (probably the reason for the heft over the stock HF engine)
10lb wheels at each corner.
battery in the trunk.
LEFT FRONT: 32.5% (648 lbs)
RIGHT FRONT: 29.4% (585 lbs)
LEFT REAR: 18.4% (367 lbs)
RIGHT REAR: 19.5% (390 lbs)
LEFT TOTAL: 50.9% (1015 lbs)
RIGHT TOTAL: 48.9% (975 lbs)
LEFT FRONT + RIGHT REAR: 1623 lbs
RIGHT FRONT + LEFT REAR: 1600 lbs
TOTAL FRONT: 61.9% (1233 lbs)
TOTAL REAR: 38.0% (757 lbs)
dang, I have one heavy CRX...no wonder why I need the 220whp. So, any recommendations on getting that 60% closer to 50%, without raising the curb weight?
Old Apr 16, 2007 | 09:19 PM
WWDTrackRacer's Avatar
New User
Default Not bad
1990, still a good weight. I'm envious. My 88 Std hatch is 2050lbs -- pretty similar configuration (B16). But I still have all glass + the bumper support.
You want to reduce the nose heavy front end? Might have to put a D-series back in.
Old Apr 16, 2007 | 11:19 PM
slammed_93_hatch's Avatar
Default Re: 1990. (Driven)
are you trying to get the front and rear weight distributions to 50%?
Why do you want to do that?
Old Apr 17, 2007 | 06:19 AM
davidnyc's Avatar
you can only change cross weights when doing corner weighting. Front to rear only changes slightly.
If you want 50-50 weight distribution front to rear, you would probably have to move the engine into the passenger compartment...
Modified by davidnyc at 9:17 PM 4/17/2007
Old Apr 17, 2007 | 11:31 AM
Driven's Avatar
Default Re: 1990. (slammed_93_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch &raquo;</TD></TR><TR><TD CLASS="quote">are you trying to get the front and rear weight distributions to 50%?
Why do you want to do that?</TD></TR></TABLE>
Not looking for a perfect 50/50, but closer can't hurt.
certainly help me from chewing thru tires.
Old Apr 17, 2007 | 11:34 AM
Andrie Hartanto's Avatar
in a FWD, you don't want 50/50. You need the weight to keep the traction in front wheel.
This car ain't a RWD
Old Apr 17, 2007 | 11:38 AM
EJ1 wilcox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Driven &raquo;</TD></TR><TR><TD CLASS="quote">
certainly help me from chewing thru tires. </TD></TR></TABLE>
Buy a miata?
+1 thing I loved about my 92 miata. Sooo well balanced.
Old Apr 17, 2007 | 12:58 PM
Tyson's Avatar
50/50 is ideal for "mid engined" (front or rear mounted) chassis where the whole drivetrain is between the two axles.
crx is not mid engined.
why didnt you weigh the car with you in it and focus on corner balancing instead?
Old Apr 17, 2007 | 01:12 PM
Driven's Avatar
Default Re: 1990. (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">why didnt you weigh the car with you in it and focus on corner balancing instead?</TD></TR></TABLE>
it was a quick weighing session. roll the car on. run the numbers. push the car off. all done in like 3 minutes. he had like 40 other cars to do in a span of maybe an hour.
Old Apr 17, 2007 | 01:33 PM
Is this on the track scale? If that's the case, the cross weight might not valid. You need a perfectly level surface to get accurate data.
Old Apr 17, 2007 | 07:23 PM
turboteener's Avatar
Banned
Without you in the car the numbers are fairly irrelavent.
Old Apr 18, 2007 | 10:32 AM
Yosshaa's Avatar
Default Re: (turboteener)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboteener &raquo;</TD></TR><TR><TD CLASS="quote">Without you in the car the numbers are fairly irrelavent. </TD></TR></TABLE>
exactly.
try a 60/40 front and rear.
SlobberGoat
Jul 24, 2006 11:32 PM
hondacivic4g
Dec 13, 2003 11:54 PM
ASNG
Dec 1, 2001 02:48 PM
HX_Guy
Oct 4, 2001 07:15 AM
HX_Guy
10
Oct 1, 2001 02:10 AM
