engine is sputtering at high rpms i have a supercharger any thoughts
perhaps you should elaborate on your situation alittle more. Under what conditions is this happening, is it at WOT, partial throttle, etc.
Have you tuned the car? Mine ran like chit with the jrsc before I got it tuned. Lower revs were "ok", like below 5K, but anything into VTEC just fell on its face. I had major fuel problems until it was tuned.
Need more info about your setup.
i jsut replaced the o2 sensor on a friends del slow. he was getting a sputtering effect after 4K rpms or thereabouts. this was diagnosed due to the car not hesitating in open loop when the car was started. and it sputtering as soon as the car went into closed loop.
replaced the o2 sensor and the problem was solved.
was the front or rear o2 replaced on the del sol?
i have on the way a hondata system and 550cc injectors, i just wanted to make sure that it wasn't an internal engine problem
existanzcivicb20
28
Feb 18, 2014 05:54 AM
D7KWagon
Nov 15, 2013 12:03 PM
5 Skware
Sep 12, 2003 07:05 PM
