broken block (motor mount)
Old Aug 14, 2004 | 08:49 PM
5STAR3's Avatar
Default broken block (motor mount)
i just traded for a block and now i have noticed that the drivers side motor mount on the block is cracked and there is a chunk missing. about half of the bolt is exposed where it should not be. i will try and get pics. up soon.
i know this is repairable, however is it worth it? i have searched for similar situations and didnt find much. however i did find one or responses where the people said that the shops quoted the outrageous prices.
so does any one have experiences and know how much this is going to run me to have it welded and tapped? and will the block ever be the same as one that has not had this problem?
thanks
Old Aug 14, 2004 | 09:24 PM
5STAR3's Avatar
Default Re: broken block (envision2teg)
Old Aug 14, 2004 | 09:56 PM
B18C1CYA's Avatar
i wouldnt think it would cost a ton because the block is out of the car right? i would just have it welded up and retaped it will be as good as new
Old Aug 14, 2004 | 10:20 PM
5STAR3's Avatar
Default Re: broken block (B18C1CYA)
so its pretty cheap when it is out of the car?
ttt
Old Aug 14, 2004 | 10:28 PM
B18C1CYA's Avatar
i would say so because it is much easyer to get to and work on so less labor
Old Sep 12, 2004 | 09:00 PM
TurboTeG4's Avatar
My engine that I just got from spark racing , I notice that it also had that damage and it was repaired. Pretty pissed about it considering I asked if the block was not damaged. Is it just as strong for 300+whp?
Old Sep 12, 2004 | 09:11 PM
5STAR3's Avatar
Default Re: broken block (TurboTeG4)
if done right it will be fine.
i did lots of research on it
Old Sep 13, 2004 | 03:38 PM
Canuk_SiR's Avatar
I did an R6 motor for a buddy of mine, charged him $50 to have it filled in and re-tapped. Machine shops will charge much more though, unless you've got a friend with his own tig machine in his garage
Old Sep 13, 2004 | 03:44 PM
fulldragcrx's Avatar
Default Re: broken block (Canuk_SiR)
Do you have the broken off peice that is supposed to cover that spot? if so the yes it can be done cheap, if you dont have tha broken off peice then its gonna get expensive. But let me ask you are all of the other mounts present and in good condition? if so i would leave it alone, just make sure that no other sections near that hole are loose or about to fall off, cause it could fall into the timing cover and cause probs later. good luck
Old Oct 21, 2004 | 01:31 PM
egb18c2's Avatar
Default Re: broken block (fulldragcrx)
Don't mind me I'm gay.
Old Oct 21, 2004 | 01:38 PM
5STAR3's Avatar
Default Re: broken block (egb18c2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egb18c2 &raquo;</TD></TR><TR><TD CLASS="quote">ENVSION2TEG has been reported for stealing my car!</TD></TR></TABLE>
riiiight.
i ended up getting a diff. block
Old Oct 21, 2004 | 02:51 PM
B6tPoweredMx3's Avatar
is it an aluminum block or cast iron?
Old Oct 21, 2004 | 03:42 PM
EL Vap133's Avatar
Bye bye!!
DCTegg
Aug 23, 2009 12:00 PM
Redprelude98
37
Mar 27, 2009 09:56 PM
Sille98
Welding / Fabrication
Jun 20, 2005 04:29 PM
sohczchf
Nov 16, 2004 12:08 PM
crxman2
Aug 24, 2002 03:13 PM
