Speedometer Stuck
Old Aug 14, 2004 | 06:07 PM
sensorsearch's Avatar
Default Speedometer Stuck
The speedometer on my 95 Accord goes to 20 mph when the key is placed in the on position. When it is started it bounces around 20 then stays there when I move the car. When I come to a stop it again starts to bounce around 20. I replaced the VSS, it didn't help. Can anyone give me some help with this?
Old Aug 15, 2004 | 11:13 AM
Canonm7's Avatar
Default Re: Speedometer Stuck (sensorsearch)
Aren't there two speed sensors? Supposedly, there is just a "Speed Sensor" that sends the signal to the speedometer and the vss sends it to the computer. Someone correct me if I'm wrong cause I'm having the same problem.
Old Aug 15, 2004 | 05:57 PM
Default Re: Speedometer Stuck (Canonm7)
I've only found one module that has to do with the speed sensor. It is below the intake on the transmission, I changed the vss and even when it is unplugged the speedometer goes to 20 mph when the key is turned to on. I'm starting to think about a grounding problem, but where do you start???
Old Aug 15, 2004 | 08:18 PM
eghatch4sale's Avatar
would like to know how to fix this problem myself anyone ever figure it out ????
Old Aug 16, 2004 | 05:45 AM
anyone fixed this problem????????? please help!!!!!!!!
Old Aug 16, 2004 | 10:24 AM
anyone?????????????????????????
Old Aug 16, 2004 | 10:35 AM
motormanSR's Avatar
Default Re: (eghatch4sale)
i woudl think it's a grounding problem. or a short circuit somewhere.....
or it might just be that your car is possesed and you need to perform an exorcism.....i will do so me more research on this
Old Aug 16, 2004 | 10:44 AM
most likely it is either the vss or the cluster is bad i know this much i also searched and found nothing helpful......i also read that if the cruise control dosent work its the vss but my cruise control works????? so i am leaning to get a new cluster i just want to see if it could be anything else ????? so all help will be appreciated thanx again!!!!!!
Old Aug 16, 2004 | 02:14 PM
some one help??????
Old Aug 16, 2004 | 04:58 PM
Since we share the same problem, do you know what is involved in changing out the cluster. What and where all the parts that have to be removed? If it is a ground, then even a new cluster won't help. If we could get some troubleshooting tips for diagnosis it might save us some major work.
Check out the following link for a wiring diagram:
http://autorepair.about.com/li...h.htm
Old Aug 17, 2004 | 08:37 AM
this is a common problem .......someone has to be able to help
Old Aug 17, 2004 | 03:05 PM
M2nR's Avatar
geees...why does everyone make their life so complicated.....why dont you just take it over to the dealer and have them check it out and tell you whats wrong... DUH
Old Aug 18, 2004 | 04:52 PM
why waste the money if you dont have too!!!! DUH????
vedha
Oct 9, 2009 09:46 PM
one slow coupe
Nov 30, 2006 12:30 PM
vtNaMeSe
Jun 21, 2003 06:55 AM
sparknblaze
Feb 5, 2003 03:47 PM
Mike95lude
Feb 18, 2002 09:50 PM
