placing MAP sensor before turbo... any possible benefits?
Old Aug 13, 2004 | 06:04 AM
igo4bmx's Avatar
Default placing MAP sensor before turbo... any possible benefits?
just thinking about it...
would running a map sensor before the turbo (aka before boost) be simliar to the idea of an FMU and check valves?
the same flow of air coming to the MAP before the turbine is the same air that would be seen at the MAP on the throttle body.....
This idea came from another thread - so don't make fun
Old Aug 13, 2004 | 06:47 AM
White Smoke's Avatar
i my honda
Global Mod
Default Re: placing MAP sensor before turbo... any possible benefits? (igo4bmx)
NO NO NO It wont work
Hence the name MANIFOLD absolute pressure.
Old Aug 13, 2004 | 06:49 AM
i my honda
Global Mod
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igo4bmx &raquo;</TD></TR><TR><TD CLASS="quote">
NO AGAIN
You may be getting MAP an MAFS sensors confused
Old Aug 13, 2004 | 06:59 AM
Muckman's Avatar
Moderator in Chief
Default Re: placing MAP sensor before turbo... any possible benefits? (si2die4)
And you compared it to the idea of a FMU and check valves. An FMU has nothing to do with what your talking about. Check Valves (missing link), yes.
The idea sounds more appropriate for MAF sensors not MAP. The difference between them is how they measure air, flow vs pressure. You may think one equals the other but its not that simple. MAFs suck.
Old Aug 13, 2004 | 07:01 AM
DaX's Avatar
DaX
Loved
Community Favorite
I can only see how this would be beneficial at WOT...the MAP would never see vacuum, so it probably wouldn't idle or have part throttle driveability.
Old Aug 13, 2004 | 07:02 AM
igo4bmx's Avatar
Default Re: placing MAP sensor before turbo... any possible benefits? (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">And you compared it to the idea of a FMU and check valves. An FMU has nothing to do with what your talking about. Check Valves (missing link), yes.
The idea sounds more appropriate for MAF sensors not MAP. MAFs suck.</TD></TR></TABLE>
i know FMU has nothing to do with MAP
i'm just giving an example of how ithought this could work, by eliminating the check valves in an FMU setup...
and now that i think of it sitting here at work, it would be bad since the map is normally sitting behind the tb plate
Old Aug 13, 2004 | 07:04 AM
Muckman's Avatar
Moderator in Chief
I think the better idea would be to just convert to a full MAF system. But Honda ECUs arent setup for that so it would be more difficult than just running a check valve or better yet getting some kind of real engine management.
fancyfruitcup
Mar 19, 2014 08:57 PM
shaggyeg6si
May 15, 2008 07:48 AM
EKB18BPR3
Apr 30, 2005 08:07 PM
Mr.NiceGuy
Apr 9, 2002 02:36 PM
