Overheating during track only. normal driving a-ok
Old Aug 12, 2004 | 06:28 PM
all stock's Avatar
Default Overheating during track only. normal driving a-ok
I was at Buttonwillow a few weeks ago and after every couple of laps I would have to pit because my temp needle gauge would rise to 3/4 from 1/2.
I own a CNR Radiator, Mugen Thermostat and Fan Switch. Coolant levels are good, it has been bleed properly countless times.
Normal driving is fine.
Anyone know:
1. What could be wrong?
2. What if I tracked the car w/o a Thermostat?
Thanks in advance. Buttonwillow was fun. First time running full course with star mazda.
Another thing to note is that it only rises when cornering on the track and also, it started a few months back when I went off into the gravel at Streets of Willow.
Old Aug 12, 2004 | 06:30 PM
B2FiNiTY's Avatar
Default Re: Overheating during track only. normal driving a-ok (all stock)
Is everything plugged in? No loose wires/connectors?
how old are your fluids? what kind are you using?
Old Aug 12, 2004 | 06:32 PM
[HrZn]4life's Avatar
I blew a headgasket not too long ago and was burning coolant endlessly but no coolant was taken from my overflow tank; I was told that this is because of my high pressure spoon radiator cap; I'm kind of sketchy about that explanation. I'm just bringing this up in case you are only checking coolant level from the overflow tank. Maybe you are low on coolant.
Old Aug 12, 2004 | 06:36 PM
MAD ITR 55's Avatar
Default Re: Overheating during track only. normal driving a-ok ([HrZn]4life)
cooling fan working?
Old Aug 12, 2004 | 06:47 PM
.RJ's Avatar
.RJ
Hoses in good shape?
Run less coolant, more water...
Old Aug 12, 2004 | 07:48 PM
Project X's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all stock &raquo;</TD></TR><TR><TD CLASS="quote">I was at Buttonwillow a few weeks ago and after every couple of laps I would have to pit because my temp needle gauge would rise to 3/4 from 1/2.
Anyone know:
Another thing to note is that it only rises when cornering on the track and also, it started a few months back when I went off into the gravel at Streets of Willow.</TD></TR></TABLE>
I have the same problem, especially when I was using the Spoon rad cap. Now it seems to be better when I use the SLANT rad cap that it came with the C&R Racing rad. I'm also using Motul Inugel Ultima (orange) and it helped quite a bit too.
born2lose
13
Aug 11, 2011 07:57 PM
drshottest718
Sep 3, 2009 10:29 AM
mrx
Jul 4, 2006 07:44 AM
M2B4
Apr 20, 2006 09:56 AM
LoooseGSR
Jul 15, 2003 10:49 PM
