Brakes. What brakes?
Old Aug 11, 2004 | 08:20 PM
Rostr02's Avatar
Default Brakes. What brakes?
Ok heres the problem. I finally have my car ready for an auto x event (kw coilovers and rear disc, better pads, stainless lines ect.) Well tonight the master cylinder was changed to an ex master cylinder along with a salvaged 4040 prop valve and super gold brake fluid. I wanted to go to an auto x event tomm so I can tune my suspension and to finally drive my car, it has been a long time since my last event at beaver. Well basically no auto x for me tomm because I have no brake pedal until I push it all the way to the ground I have e brakes but at speed I do not want my brakes to fail
Any suggestions on what can be wrong with my brakes. A rollcage is going to be going in soon but i need to get this whole brake thing figured out before that happens.
Someone please help I need to get back to racing
Thank you Robert Ostrowski
Old Aug 11, 2004 | 09:30 PM
travis's Avatar
Default Re: Brakes. What brakes? (Rostr02)
It really could be anything at this point with all the mixing and matching of new parts. Search for info on MC swaps including bench bleeding, then check for leaks. Finally, grab your shop manual and properly test the new equipment to make sure you didn't introduce a new problem into your system.
Old Aug 12, 2004 | 04:25 AM
sinister6's Avatar
good luck in the event, its like a SEA out there.. dont worry about the DNF tho..
Old Aug 13, 2004 | 08:44 PM
Rostr02's Avatar
Default Re: Brakes. What brakes? (travis)
going to try changing the MC tomm and see if thats the problem. otherwise i will have to check all of my calipers that will not be fun. Thanks for the advice
imbest123
Nov 19, 2011 08:49 PM
jasonweaver88
Jun 29, 2007 10:31 AM
kurinto
16
May 4, 2005 03:42 PM
DriveSideWays
Aug 7, 2004 05:34 AM
ITR1071
May 25, 2002 02:46 PM
