Primary O2 Sensor bad, need ideas!
Old Aug 11, 2004 | 02:20 PM
Shakes's Avatar
space cadet
Default Primary O2 Sensor bad, need ideas!
Currently I am throwing a code 61 (bad primary o2 sensor). This came on about a week and a half after installing my Prospeed Header / test pipe and secondary o2 sensor simulator.
The header leaned the car out considerably, actually changing the plugs from pitch black to white and slightly pitted within minutes.
There are a couple of options that I was thinking.
A - I am running too lean therefore it is giving the code.
B - Possibly something with the Secondary o2 sensor simulator is messing with the ECU too much.
C - After bottoming out one too many times (maybe 4 or 5 times) the o2 sensor is pissed at me.
Right now I am not even in the good ol' USA so I cant check my car, but I have been thinking about it considerably and would like to get some ideas.
Can running too lean throw that code?
Old Aug 12, 2004 | 01:50 AM
Shakes's Avatar
space cadet
Default Re: Primary O2 Sensor bad, need ideas! (Shakes)
anybody?
Old Aug 12, 2004 | 05:30 AM
JimBlake's Avatar
Code 61 is 'slow response' of the primary O2 sensor. So therefore...
A - NO. Lean shouldn't cause that code.
B - NO. 2nd sensor isn't supposed to mess with 1st.
C - Maybe that's the real cause???
I suppose it can be simply the sensor is old, maybe bottoming out didn't do it. But you're still gonna want to get a new sensor.
Old Aug 12, 2004 | 10:06 AM
Shakes's Avatar
space cadet
Default Re: Primary O2 Sensor bad, need ideas! (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">Code 61 is 'slow response' of the primary O2 sensor. So therefore...
2nd sensor shouldnt thats true, i have just been "told" by people that there is experiance with the secondary o2 simulators jacking with it all.
since i am not using the secondary can i use that to replace the primary?
thank you for the response by the way.
Bossup!
Sep 9, 2009 07:35 PM
98savage
Jun 15, 2007 09:35 PM
amej8
Jul 11, 2006 06:25 PM
JibOnALib
Aug 25, 2005 08:54 PM
GSRacer
Oct 8, 2001 06:59 AM
