How hard is it to install...
A roll of tin foil and some wire will go about 500 miles before a hole burns through it.
EDIT - It appears I have replied to the wrong thread. LoL. sorry.
[Modified by sackdz, 3:43 PM 11/30/2001]
You can do it without a spring compressor, it just takes a little abstract thinking. You unbolt the top while it's still on the car, and under weight, then you jack the car up, and unbolt the rest of the stuff. You are basically using the cars weight as your spring compressor.
Air tools make it reall easy.. you need a spring compressor..
and then you need to have the alignment done....
oops I forgot.. you need the upper ball joint transfered to your new Upper control arms..
thats probably something you can't do....
hmmm
hmmm
All_JDM_Si
Sep 29, 2003 11:00 PM
