bad rings? any way to tell by looking at them?
Old Aug 11, 2004 | 12:08 PM
siis2fast's Avatar
Default bad rings? any way to tell by looking at them?
i had low compression in one of my cylinders, so i ended up just pulling my motor apart as it was spraying oil out the exhaust.
but, the rings look the same on all my pistons, and i even ordered new rings and they all look identical.
i dont see any chips, or anything on any of them.
and, the new rings have a slightly larger gap on them, could it be because the old rings were compressed for so long and the new rings havent been compressed yet>?
Old Aug 11, 2004 | 12:47 PM
vtecb20coupe's Avatar
B A N N E D
Default Re: bad rings? any way to tell by looking at them? (siis2fast)
the rings may not have seated, could be a pcv valve, could be bad seals, etc. too many variances.
Old Aug 12, 2004 | 04:17 PM
siis2fast's Avatar
Default Re: bad rings? any way to tell by looking at them? (vtecb20coupe)
thats exactly why im trying to see if there is a way to tell if the rings are bad specifially because of the rings or not.....
Old Aug 12, 2004 | 04:47 PM
GZERO's Avatar
check your cylinder, run your finger nails and see if it gets caught on something, also, check to see if the cylinder walls are uniform, especially on the top.
ZCHondaCRX91
Engine Machining & Assembly
Sep 14, 2015 04:23 PM
existanzcivicb20
Sep 29, 2014 05:33 AM
h22aBB4
Dec 26, 2006 02:43 AM
riceball777
Jan 17, 2004 09:41 PM
non-VTEC
Oct 26, 2002 08:15 AM
