power windows not working, 93 EX coupe
hey this is just for confirmation, but i had my passenger side window stop working last night and its stuck down
anywho, i checked the fuse and it was fine, but seeing as how it doesnt work from either the switch in the driver side door or the switch in the pass side door.. the only thing it could be is a dead window motor, right? just confirming my fears that its the most expensive repair something like this could need.. short of replacing the whole door.
I would try taking off the panel to that door and hot wiring the motor for the window, just to double check what your problem is.
found the problem, turned out that the plug that went into the ON/OFF switch under the driver side control panel had been knocked loose. window motor is good and strong, checked it with a 12v battery. thanks for the tip
elcapy
16
May 9, 2018 08:22 PM
commotion
Jul 19, 2006 08:51 PM
