Update on my sputtering. Anyone had cracked manifold or other leak around there??
Old Nov 30, 2001 | 08:16 AM
DamonBoost's Avatar
New User
Default Update on my sputtering. Anyone had cracked manifold or other leak around there??
I orginally thought the sputtering was from water in the plug holes. Well I dryed all of those out and have been driving it at least 20min a day twice a week all week and it is still doing it. I started thinking it could be other stuff.
I couldnt resist it.. Last night at 12:30am I took my car to the carwash so I could see and did a compression test. My results were the same as last time but this time I had some oil on the plugs. I did a wet compression test about two weeks ago. Could that oil be left over from that? I am going to replace my piston rings this month..But I do think I found my problem. I hear a small exhaust Leak in the manifold area. I didnt hear this until I got back to my apartment where I cant see. I also noticed my idle is a little rough. My question to all of those who either cracked their turbo manifold, blew their manifold gasket, or had a leak at their downpie what were your symptoms? I am having a loss of power in the upper range of 2nd, 3rd, and 4th gear. It starts losing power and sputtering sorta from about 4000RPM untill I shift. I am also feeling a little vibration in front end due to this. I figure it is form the sputtering.. Also an Acura mechanic is supposed to help me replace my rings. Will we be able to do this in a weekend? How hard is it? We have a lift so he said we will do it from under the car..
Old Nov 30, 2001 | 08:20 AM
Doodoo's Avatar
Default Re: Update on my sputtering. Anyone had cracked manifold or other leak around there?? (Damon501)
I had a leak in my WG elbow, well it almost cracked off! Anyways, My symptoms were it would not hold boost or ample vacuum(when moving). I would hold at about 3500RPM and watch my guage drop from around zero to 10-15 vacuum.
Old Nov 30, 2001 | 08:27 AM
DamonBoost's Avatar
New User
Default Re: Update on my sputtering. Anyone had cracked manifold or other leak around there?? (Doodoo)
It is holding boost fine...
Old Nov 30, 2001 | 09:57 AM
DIRep972's Avatar
Smarter than you
i bet its your exhaust manifold gasket..
Old Nov 30, 2001 | 10:53 PM
DamonBoost's Avatar
New User
Default Re: Update on my sputtering. Anyone had cracked manifold or other leak around there?? (DIRep972)
any more opinons??
Old Nov 30, 2001 | 11:53 PM
Full-Race Geoff's Avatar
sounds like a crack to me... there is an exhaust leak pre-turbo somewhere. Either a cracked manifold or the exhasut gasket is leaking. With an exhaust leak it can make/produce boost but it will neither be effective boost nor accurate.
Old Dec 1, 2001 | 07:51 AM
DamonBoost's Avatar
New User
Default Re: Update on my sputtering. Anyone had cracked manifold or other leak around there?? (FFgeoff)
Thanks geoff, I think actually it might be a leak where the turbo bolts on to the manifold and also it looks like my downpipe maye be cracked.. Could these problems cause the same symptoms??
Old Dec 1, 2001 | 09:27 AM
if the flange on the turbo from the downpipe is warped/cracked (if you have a 5 bolt turbo that is) you can get a leak there too. But the leak must be pre-turbo... look for black smoke at the DP flange, or at the turbo flange or the head flange. You can see the carbon deposits... that means a leak.
Old Dec 1, 2001 | 11:02 AM
DamonBoost's Avatar
New User
I see white stuff, Looks like white deposits.. What does that mean?
Old Dec 2, 2001 | 01:18 PM
GruvyTune's Avatar
New User
Are tiny leaks tolerable??
Old Dec 2, 2001 | 04:27 PM
supadupamikey's Avatar
I see white stuff
LOL!
maybe its just me... but between the sixth sense, scary movie and my 22yr old male hormones, this came across really funny!
Old Dec 2, 2001 | 04:33 PM
DamonBoost's Avatar
New User
Default Re: Update on my sputtering. Anyone had cracked manifold or other leak around there?? (lilmikey77)
I see white stuff
LOL!
lmao..
blazin99si
Jan 22, 2008 06:42 PM
Fatty_1775
Sep 20, 2006 03:13 PM
JM Performance
Jan 21, 2005 08:58 AM
bxsi
May 18, 2003 09:42 AM
Turbo Powa
Apr 3, 2003 08:15 AM
