i need some info
Old Dec 2, 2001 | 01:53 PM
Cyber ITR's Avatar
Default i need some info
whats the different between blockguarding and sleeving ?
which one is better ? and more expensive ?
thanks guys
Old Dec 2, 2001 | 04:53 PM
Dr.James's Avatar
Default Re: i need some info (VTEC_SiR)
The block guard is a piece of aluminum that is press fit into the water jackets around the free standing cylinders. the guard helps to stabilize the cylinders under pressure. Sleeves are generally ductile iron, and replace the stock sleeves in the car. Depending on what engine you have, if you want to run forged pistons, you will need to have the sleeves done. In my Prelude the stock cylinders had nikisil lining on them. You can't run forged pistons with nikisil lining. Cost wise Sleeving the block is more expensive. And most people that I have talked to don't like the block guard anyway. Sometimes you can run into overheating problems with the blockguard.
GT500FTW
Nov 3, 2014 02:32 PM
hizler07
Sep 14, 2007 03:21 PM
fknfast
Jan 23, 2004 09:47 AM
Beast53568
Aug 5, 2002 11:05 PM
97PreludeSH
Sep 25, 2001 10:37 AM
