question about a h22a engine harness
Old Aug 10, 2004 | 09:17 PM
3.point.2's Avatar
Default question about a h22a engine harness
i have a quick question. can a h22a engine harness be modified to work with an h23a1? if so then how. i need an engine harness for my h23 swap in my hatch. i have access to a jdm h22 harness and id like to know if i can some how use that. cant use the h23 harness because thats on the h22. the guy at the shop couldnt figure out a way to use the h22 harness. any help is appreciated. i need to find some kind of harness that will work ASAP.
Old Aug 10, 2004 | 09:27 PM
v4lu3s's Avatar
RTFM
the only diff between an h23 and h22 harness is the vtec wiring, all else is identical. and the guy at teh shop is a ******* retard for trying to use an h22a harness, he need to take the original civic engine harness and mod ify it to fit the new engine.
Old Aug 11, 2004 | 07:54 AM
3.point.2's Avatar
he wasnt trying to use the h22a harness on the civic he was trying to use it on the prelude.
Old Aug 11, 2004 | 02:40 PM
v4lu3s's Avatar
RTFM
well i assumed you were putting an h23a1 into your civic cx shell. to make that happen i wold use the civic cx engine harness and moidfy it with pieces of the H series harness that you vut out of the H series harness and splice into the D series harness.
Old Aug 11, 2004 | 04:28 PM
3.point.2's Avatar
could these pieces be taken off the h22a harness? what pieces would need to be used? using anything from the h23a1 harness is not an option because that harness was put on the h22a which is now in my friends lude.
Old Aug 11, 2004 | 06:05 PM
v4lu3s's Avatar
RTFM
jsut use what you need fromt eh H series harness, the h23 and h22 harnesses are almsot all teh same anyway. the onyl plugs you woul dneed ot tangle with are for egr, knock and iab anyway. hell you could even use a most any ohter harness to scavenge plugs from as well.
UniqueX707
Nov 24, 2014 11:33 AM
mike541
Apr 13, 2011 01:40 PM
FunnyVictor86
Dec 28, 2008 04:15 PM
3.point.2
Aug 7, 2004 03:29 PM
mstsh80
Jul 1, 2003 12:49 PM
