chip or safc?
Old Aug 10, 2004 | 04:03 PM
Chris_Bye's Avatar
Default chip or safc?
right now i have a jet chip and an safcII in my car. the jet chip hardly was noticeable but i havent touched the safc yet. should i send back my jet chip and get $250 back or keep it?
Old Aug 10, 2004 | 05:18 PM
Dc2 Powered's Avatar
safc.
Old Aug 10, 2004 | 06:20 PM
Chris_Bye's Avatar
Default Re: (Dc2 Powered)
bump...
Old Aug 10, 2004 | 06:38 PM
Padawan's Avatar
Darth ModerVader
Default Re: chip or safc? (91ntegra)
Definitely send back the chip if you can, and put that money towards proper tuning with the S-AFC.
Old Aug 11, 2004 | 06:09 AM
Chris_Bye's Avatar
Default Re: chip or safc? (Padawan)
yeah i can send the chip back because it's a jet chip and there are seals on the computer that aren't broken. i'm going to do that and get some dyno time to tune.
Old Aug 11, 2004 | 06:25 AM
neo1z's Avatar
Good call
Old Aug 11, 2004 | 07:12 AM
verticle's Avatar
Default Re: chip or safc? (neo1z)
ditch and tune. $250 is alot of cash. get that **** back!
Old Aug 11, 2004 | 08:02 PM
boosted k20's Avatar
Send that JET chip back and buy yourself an EPROM burner to burn your own chips. Use this program called Uberdata to change ur fuel and ignition maps, raise ur rev limiter, change ur VTEC engagement point, retard timing according to boost pressure, etc. This program is like Hondata but FREE. U just need to buy an chip burner and the chips. but u need to know how to tune it.
check it out: http://www.ecimulti.org/uberdata/
Old Aug 11, 2004 | 10:06 PM
alfaaay's Avatar
Default Re: chip or safc? (boosted k20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted k20 &raquo;</TD></TR><TR><TD CLASS="quote">Send that JET chip back and buy yourself an EPROM burner to burn your own chips. Use this program called Uberdata to change ur fuel and ignition maps, raise ur rev limiter, change ur VTEC engagement point, retard timing according to boost pressure, etc. This program is like Hondata but FREE. U just need to buy an chip burner and the chips. but u need to know how to tune it.
check it out: http://www.ecimulti.org/uberdata/</TD></TR></TABLE>
If you've already got a socketed ECU and are OBD1, Uberdata is a great way to go. Get a quality wideband O2, and a chip burner, and you'll be able to do some tuning on your own.
aznsmtboy's Avatar
You can also check out CROME, I'd ditch the SAFC and the Jet chip, get the EPROM burner like boosted said and start messing around with self tuning, begin your self tuning adventure by reading this website's forums and FAQ's http://www.pgmfi.org
HerbNRacer
Engine Management and Tuning
17
May 9, 2016 10:56 PM
Honda4life777
Jul 11, 2009 09:39 PM
the.hamburglar
Mar 20, 2006 03:28 PM
JayDM_lsvtec
Apr 7, 2005 03:40 PM
