Anyone used Aerosol Touch Up Spray Paint does it work well?
Old Aug 10, 2004 | 02:16 PM
abstractj's Avatar
Default Anyone used Aerosol Touch Up Spray Paint does it work well?
1992 Honda Accord need to repaint part of a rear panel about the size of a grapefruit. It's pretty smooth and pretty flat surface. Thinking about doing it as a DIY job with Aeorsol touch up spray and primer. Anyone done this before?
Old Aug 10, 2004 | 02:22 PM
madd's Avatar
Default Re: Anyone used Aerosol Touch Up Spray Paint does it work well? (abstractj)
just use nice even strokes...you may want to read in on some basic wet sanding techniques....make sure you let each coat dry, but other than that....i think you should be ok. good luck
Old Aug 10, 2004 | 02:26 PM
abstractj's Avatar
Default Re: Anyone used Aerosol Touch Up Spray Paint does it work well? (madd)
How many coats do you recommended? I'm so afraid it's not going to match... but then again it's not matching at all right now.
Old Aug 10, 2004 | 02:57 PM
typeR#0427's Avatar
I don't think that the color will match very well.
Old Aug 10, 2004 | 03:00 PM
abstractj's Avatar
Default Re: Anyone used Aerosol Touch Up Spray Paint does it work well? (hamB18C5)
Well, I was told to apply several coats then wet sand. After paint dries use clear coat and then rubbing compound. The color of my car is Honda Maroon red which is prett common. Please elaborate why you don't think it will match well.
Thanks.
jayturboef
Paint and Body
20
Apr 20, 2010 11:39 PM
sandturtle
Paint and Body
Apr 18, 2008 08:57 PM
xcellorator
Apr 26, 2005 03:37 AM
j.Ngo
Apr 25, 2002 06:59 PM
Splat
Apr 15, 2002 01:45 PM
