Replacing the ECU - f23 alternatives
Old Aug 10, 2004 | 12:51 PM
swift535's Avatar
Default Replacing the ECU - f23 alternatives
ok well i'm not looking to get bitched at for speeding but my 02 6th gen does indeed have a rev limiter. I know it sounds crazy because it doesn't come stock, but the dealership must have installed one. It shifts into 4th at about 4300rpms but then it drops down to 4k and holds, it won't pull past 4k in 4th gear which limits it to 105mph and me to 3rd gear runs.
i got a buddy who plays with his b16 with uberdata, would it be possible for him to just remove the rev limiter for me? Or are there other options for a plug-n-play install? I know the p28 ecus are used for hondata setups, but I'm not sure if those will work with my auto. Any help would be great guys (n gals), thanks
Old Aug 10, 2004 | 01:06 PM
ash.zero's Avatar
Default Re: Replacing the ECU - f23 alternatives (swift535)
in my 99 accord (f23a1), i've gone 130ish. you can't go past 105? something's wrong with your car.
Old Aug 10, 2004 | 03:43 PM
Steed77's Avatar
Default Re: Replacing the ECU - f23 alternatives (ash.zero)
I have not had the place yet to test mine out. However @105 I had no issues. By the way I have an 01.
Old Aug 10, 2004 | 05:08 PM
v4lu3s's Avatar
RTFM
bd1 conversion and a p28 will work wonders once you chip it and tune it...if you were 5 spd, being an auto you are fuct pretty much.
Old Aug 10, 2004 | 06:08 PM
16.45_stock_94accord's Avatar
Default Re: (v4lu3s)
im not tryin to be a jerk or nething.. i got a 5th gen 5 speed tho.. im wondering how ur doin 105 in 4th at 4300 rpms... at 4300 rpms in 4th my car is goin about 80-85ish.. just wondering if ur tach is messed up or is it just that much difference in the gearing??.. thx
Old Aug 10, 2004 | 06:11 PM
madd's Avatar
Default Re: (16.45_stock_94accord)
i have a 95 lx auto and im only around 4300 - 4500 rpm when i do 100 - 110 or so...
Old Aug 10, 2004 | 08:01 PM
swift535's Avatar
if you have a 5spd then your gearing will be different, because you have an extra gear they can be shorter (another reason why sticks are better than autos, that extra gear helps to keep in the powerband)
I know that the car should be able to go 120-130np, hell its not even stock I have intake/exhaust/nitrous.
What other than the ECU would cause that though? Nothing I know of, so best I can figure is the dealership installed a lower rev limiter than Honda intended. So no one has any suggestions? What if I just went to a junk yard and got an f23 ECU, i should be able to swap it in right? At least that would let me know if it is really an ecu.
Old Aug 11, 2004 | 08:15 AM
swift535's Avatar
---ttt---
Old Aug 11, 2004 | 09:24 AM
notoriousB's Avatar
Default Re: (swift535)
do you have a DX model? I think the DX's DO have a rev limiter right around 105-110
edit: and to run an OBD1 ECU on the 6th gen you need to install an OBD1 IAC sensor.... just an FYI
Old Aug 11, 2004 | 10:10 AM
swift535's Avatar
02 ex.... i'm wildman from honduh
turbodcxbro
Engine Management and Tuning
12
Jun 1, 2013 04:14 AM
1995honda
18
Oct 22, 2009 04:01 PM
sageuvagony
Sep 9, 2008 11:26 AM
eppyhonda
Oct 8, 2005 11:01 AM
Cidone
Nov 28, 2004 08:24 PM
