Stock ITR shifter vs. Skunk2 short shifter - which?
Old Aug 10, 2004 | 06:22 AM
JinDIESEL's Avatar
Default which is betteR - skunk2 short shifter or jdm type aRRR OEM stock shifteR?
my jdm b18c-R engine (thanks totaljdm.com) came in with the stock short shifter on it. dual bend. question is should i just sell that OEM short shifter and use the skunk 2 dual bend shifter, or keep the stock and sell the skunk2? anyone using the stock jdm type R shifter? how's the throw compared to the skunk2?
Old Aug 10, 2004 | 06:59 AM
JinDIESEL's Avatar
Default Re: which is betteR - skunk2 short shifter or jdm type aRRR OEM stock shifteR? (JinDIESEL)
Old Aug 10, 2004 | 08:22 AM
Rob :190:'s Avatar
keep the stock lever and get some bushings
Old Aug 10, 2004 | 08:25 AM
MrHeeltoe's Avatar
I am partial to the Fastline Shifter for performance duties....for regular folks I say Stock is the best.
Old Aug 10, 2004 | 09:47 AM
CWTegRNo.160's Avatar
Default Re: which is betteR - skunk2 short shifter or jdm type aRRR OEM stock shifteR? (MrHeeltoe)
stock
Old Aug 10, 2004 | 10:09 AM
Nishant's Avatar
Default Re: which is betteR - skunk2 short shifter or jdm type aRRR OEM stock shifteR? (CWTegRNo.160)
stock or C's short shifter (not made anymore)
Old Aug 10, 2004 | 10:17 AM
TypeRPaul's Avatar
i second c's if u can fins it...im very happy with mine
Old Aug 10, 2004 | 10:28 AM
NiceDc2r's Avatar
Default Re: (TypeRPaul)
OEM
Old Aug 10, 2004 | 01:18 PM
JinDIESEL's Avatar
Default Re: (NiceDc2r)
Old Aug 10, 2004 | 04:22 PM
mugenracer's Avatar
Is the JDM shifter the same as US ITR shifter?
Old Aug 10, 2004 | 04:59 PM
NiceDc2r's Avatar
Default Re: (mugenracer)
yes the linkage is bronze though
Old Aug 10, 2004 | 05:44 PM
Kengs's Avatar
FYI - C's is back in business.
The new company is called Unicorn Co. Ltd; I have no idea why.
Old Aug 10, 2004 | 07:39 PM
98itr0448's Avatar
I had a B&M, but just bought a Skunk2 this weekend. It was a good investment to say the least. The stock shifter really isn't bad, but lacks the confidence of the SK2. If you get the skunk2 **** also, like I did, it may make the feel even better than w/o it. It also sits at pretty much the same height as stock, but shifting is obviously improved. The SK2 has a sealed bearing in the bottom of the shifter, that makes a huge difference in feel v.s stock plastic bushings.
Overall I've noticed shorter throws with otherwise stock characteristics as far a looks ect. It significantly reduced the sloppyness of the stock shifter and gave my car a greater confidence through the gears. I'd say buy it, if not get a C's b/c everyone swears by them so I'd imagine their pretty nice. Although quite a bit more expensive than even a 125.00 SK2.
Old Aug 10, 2004 | 07:43 PM
Willard's Avatar
Default Re: which is betteR - skunk2 short shifter or jdm type aRRR OEM stock shifteR? (Rob :190:)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rob :190: &raquo;</TD></TR><TR><TD CLASS="quote">keep the stock lever and get some Mugen bushings</TD></TR></TABLE>
Old Aug 10, 2004 | 07:57 PM
mugen_fit's Avatar
Old Aug 10, 2004 | 09:29 PM
MAD ITR 55's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rob :190: &raquo;</TD></TR><TR><TD CLASS="quote">keep the stock lever and get some bushings</TD></TR></TABLE>
I have found this works the best.I had the skunk 2 shifter for awhile but I liked the stock one better.
Old Aug 11, 2004 | 10:48 AM
JinDIESEL's Avatar
Default Re: which is betteR - skunk2 short shifter or jdm type aRRR OEM stock shifteR? (98Itr-0448)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98Itr-0448 &raquo;</TD></TR><TR><TD CLASS="quote">I had a B&M, but just bought a Skunk2 this weekend. It was a good investment to say the least. The stock shifter really isn't bad, but lacks the confidence of the SK2. If you get the skunk2 **** also, like I did, it may make the feel even better than w/o it. It also sits at pretty much the same height as stock, but shifting is obviously improved. The SK2 has a sealed bearing in the bottom of the shifter, that makes a huge difference in feel v.s stock plastic bushings.
Overall I've noticed shorter throws with otherwise stock characteristics as far a looks ect. It significantly reduced the sloppyness of the stock shifter and gave my car a greater confidence through the gears. I'd say buy it, if not get a C's b/c everyone swears by them so I'd imagine their pretty nice. Although quite a bit more expensive than even a 125.00 SK2.</TD></TR></TABLE>
yea, i already bought the skunk2 shifter and **** since my car is auto. i never imagined that the linkage was gonna come with the stock shifter.. most likely, ill sell the stock jdm shifter here... FOR SALE: JDM ITR stock short shifter!!!!!! hehe
Stopsign32v
Transmission & Drivetrain
Apr 20, 2011 08:38 AM
SoyMilk
55
Mar 27, 2010 10:11 AM
Han Solo
Jan 8, 2007 01:01 PM
itr_dc2
Jul 9, 2004 01:59 AM
turbo_b18c
Sep 16, 2001 11:19 PM
