have a FIELDS VTEC CONTROLLER wats the stock settings for a z6 motor
im not asking for the stock vtec point
but the fuel adjustments i need to set it back stock settings
ttt
everytime i go on WOT with my vtec controller a check engine light comes on, i need to know the stock fuel settings i should put it to
put all the settings to 0 +/- (that way it doesnt modify the map signal, and the ecu reads what the map sees)
if u go too high on #+, u will add to much map voltage, that the ecu will think is seeing boost and trow a MAP sensor code
i had it and thats what happened to me
i had my car dyno tuned once on it on my N/A Z6, and i actually had it from -16% all the way to -2% to get it running right
at least for now , put them on 0+/- and vtec at 4800, beep at 7200
when it therw the code did ur idle go up high? when i turn mine on and go on WOT check engine light comes on and idle goes up to about 1,500 couple days ago i decided to turn it on **** just turned off lol(the car)
ScrapinSi
Aug 28, 2002 11:33 AM
