1000-1500 rpm "choking"
Old Nov 29, 2001 | 09:35 PM
jdmrealm's Avatar
New User
Default 1000-1500 rpm "choking"
At 1000-1500 rpm my car "chokes" likes its turning on and off...if I give a bit too much gas...its chokes if i dont it doesnt. Im thinking its my distributor cap..either that or plugs and wires right?
Old Nov 29, 2001 | 11:32 PM
Turbohatch's Avatar
New User
Default Re: 1000-1500 rpm "choking" (4g63turbo)
it might be the ecu?? did this problem happen before install of ecu. also check your spark plug wires for the right cylinder match up
Old Nov 30, 2001 | 01:55 AM
Type Goch's Avatar
New User
check for any kinda leaks, and check your TB also.
Old Dec 1, 2001 | 01:48 AM
jdmrealm's Avatar
New User
Default Re: 1000-1500 rpm "choking" (Type Goch)
You guys dont think its from the distributor cap? Its not the ecu cause it JUST started happening.
Old Dec 1, 2001 | 10:58 PM
jdmrealm's Avatar
New User
it could be the sparks too..im going to change the sparks and wires and see if it still does it.
Old Dec 2, 2001 | 05:07 PM
b18b98's Avatar
check your timing also..
Old Dec 2, 2001 | 09:50 PM
Pacman
Guest
Posts: n/a
check Tb Sensor. Any check engine light??
My web page.................http://www.geocities.com/teampacman
TeamPacman...................Marouj
stupid is what stupid does............
WWW.IMPORTBUILDERS.COM
Old Dec 10, 2001 | 01:13 PM
jdmrealm's Avatar
New User
Default Re: 1000-1500 rpm "choking" (Pacman)
No check engine lights...ill check sparks and wires...maybe that will help.
Old Dec 12, 2001 | 10:42 PM
ALLMOTORKING's Avatar
TPS SENSOR
ls_turbo_#97
Oct 19, 2009 02:28 PM
dcsports
Dec 7, 2008 06:54 PM
Downz
Feb 11, 2007 06:52 PM
ED8REX
Apr 25, 2006 09:25 PM
SamC
Sep 3, 2003 06:28 PM
