engine stutters and stalls after driving for a while
Actually a friends car. It only does it after it has been driven for a while, and the car doesnt over heat. I'm thinking its either fuel filter or the ignition coil. I'm reallie hoping its not the coil, but I think it is because the coil behaves differently with temperature wheras i dont believe the fuel filter/fuel does. He has an external coil too.
What do you guys think it is? could be something else? I guess im going to try changing the fuel filter first, but I dont think it will do n e thing.
What model and how many miles on the car?
Does he have any modifications?
When was the last maintenance done, and what was done?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mingbling »</TD></TR><TR><TD CLASS="quote">Actually a friends car. It only does it after it has been driven for a while, and the car doesnt over heat. I'm thinking its either fuel filter or the ignition coil. I'm reallie hoping its not the coil, but I think it is because the coil behaves differently with temperature wheras i dont believe the fuel filter/fuel does. He has an external coil too.
What do you guys think it is? could be something else? I guess im going to try changing the fuel filter first, but I dont think it will do n e thing. </TD></TR></TABLE>
sounds like sumthin wrong wit ur fuel filter or injector to me....
Mine does something similar as well. It doesn't sputter and stall, but once warmed up or started on a hot day, and it will tend to idle lower and rougher. Especially if i turn the A/C on, I can get my car close to stalling---and i have good compression across the board!
Must be something with fuel delivery, injectors, spark... something?!
