my compression test PIC: and some questions
Old Aug 8, 2004 | 09:13 AM
DarkBB4's Avatar
Default my compression test PIC: and some questions
i want to get some skunk2 cams and unorthodox pullies.. What would ths cost me
Parts + labor= # hp?
Old Aug 8, 2004 | 10:40 AM
DarkBB4's Avatar
Default Re: my compression test PIC: and some questions (DarkspeedVtec95)
bump
Old Aug 11, 2004 | 09:50 AM
DarkBB4's Avatar
bump... good bad.. someone help?
Old Aug 11, 2004 | 10:22 AM
prelittlelude's Avatar
maybe you should type out what it says for those of us who can't read scribble
Old Aug 11, 2004 | 10:27 AM
DarkBB4's Avatar
Default Re: my compression test PIC: and some questions (prelittlelude)
Actually, the guy who ownd the car befor me did this test.. so i can't read it any btter than u gusy... BUT it shoudln't be tha tdifficult
Old Aug 11, 2004 | 10:34 AM
PreludeRacer023's Avatar
your cylinders shouldnt have that much variance in compression..250...225..225...240...doesnt look that good to me.....usually you want them within 5 and 10 at the very most but even 10 is pushing it
Old Aug 11, 2004 | 10:35 AM
DarkBB4's Avatar
Default Re: my compression test PIC: and some questions (PreludeRacer023)
****, what could this be?
DarkBB4's Avatar
the problem i mean... so nitrous would be out of the question? like a 50 shot?
Old Aug 11, 2004 | 11:19 AM
Behan's Avatar
The difference between the cyl's (#2 and #3) means those rings are starting to go.
I wouldn't recommend nitrous, BTW is this a JDM h22a?
Old Aug 11, 2004 | 12:59 PM
DarkBB4's Avatar
Default Re: my compression test PIC: and some questions (Behan)
usdm h22
Old Aug 11, 2004 | 01:00 PM
DarkBB4's Avatar
damn, i w ish i had posted tihs before.. um... is there anything i can do? Or when will i know when my rings are busted....?
This is gonna be expensive isn't it?
Old Aug 11, 2004 | 01:16 PM
Behan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkspeedVtec95 &raquo;</TD></TR><TR><TD CLASS="quote">damn, i w ish i had posted tihs before.. um... is there anything i can do? Or when will i know when my rings are busted....?
This is gonna be expensive isn't it?</TD></TR></TABLE>
Well since its a usdm h22 ( reason below) i recommend doing the test yourself. A compression tester is only about 40.00 bucks. The test may have been done incorrectly, and before you start thinking about a rebuild ( $$$$ ) you should be absolutely positive there is a problem.
A stock usdm h22 should be around 210 psi, you may have alot of carbon buildup which would explain the difference in compression between the cyl's. The wet test didn't show a huge increase in compression so your rings might be fine.
Old Aug 11, 2004 | 01:24 PM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Behan &raquo;</TD></TR><TR><TD CLASS="quote">
you may have alot of carbon buildup which would explain the difference in compression between the cyl's. </TD></TR></TABLE>
and also it would explain why his numbers are as high as 250psi
maybe try a little seafoam, see if that will clean things up a little bit.
also if your skeptical about the numbers do a leakdown test.
Old Aug 11, 2004 | 01:27 PM
Behan's Avatar
Default Re: my compression test PIC: and some questions (SKDRCR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR &raquo;</TD></TR><TR><TD CLASS="quote">
thas why i asked if it was a jdm h22a.
Old Aug 11, 2004 | 01:31 PM
DarkBB4's Avatar
alright so u gys think i should go to an auto store, by a Tester and some seafoam and give it a try?
Old Aug 11, 2004 | 02:12 PM
Behan's Avatar
i would just buy the tester at first. I personally wouldn't have a problem with alittle more compression.
Although i'm not entirely sure whether extra compression<U> from</U> carbon is a good idea. Or if its something you should be trying to get rid of?
Old Aug 12, 2004 | 06:51 AM
DarkBB4's Avatar
so u guys think that my 2nd and 3rd are in troulbe? How serious is this problem?
Old Aug 12, 2004 | 07:09 AM
Behan's Avatar
Did you have it re-tested?
A stock usdm h22 should be around 210 psi, you may have alot of carbon buildup which would explain the difference in compression between the cyl's. The wet test didn't show a huge increase in compression so your rings might be fine. </TD></TR></TABLE>
Old Aug 12, 2004 | 07:13 AM
DarkBB4's Avatar
no i guess i should asap... this was tested a a while ago
eric416
Apr 29, 2009 02:16 PM
Haccordclub
May 21, 2007 08:08 AM
xvietxkhmerxboix
Mar 3, 2006 03:05 PM
93H22APrelude
Jul 31, 2005 05:30 PM
gsr~hatch
Apr 17, 2003 03:19 PM
