mounting problem with ek swap
i have a 96 civic and i am swaping in a 96 ls motor...........i bought a mounting kit but the driver side mounts doesn't fit right.can anyone help i need my car done.i will post some pic soon asap
this is the bracket that is on the driver side.. ...size up to the mount bracket from the kit(holes doesn't line up)
this is the stock civic bracket with the new mounting bracket on it(it line up perfect)
this is the 96 ls motor i will be using
Modified by b16a1integra at 2:18 AM 8/8/2004
Modified by b16a1integra at 2:21 AM 8/8/2004
Modified by b16a1integra at 10:27 AM 8/8/2004
I've done a swap on my cousin's civic hx with an b18b motor too. And we use just englarge the holes with a drill so it would fit. It was ghetto and my cousin was a cheap ***. Another one I did i use a 99-00 driver side mount and the side egine mount bracket and everything bolted right up, i think
Its been 3 years since I've done this swap. Which mounting kit did you get?
You have to use the bracket (the one that attaches to the engine block) from a 99-00 SI. I just did my swap not long ago and it went just fine. Hope that helps.
i bought a hasport kit................the driver side engine bracket can be bought at honda???????or do they have a aftermarket one?????????and thanks for the help guys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JoseCuervo »</TD></TR><TR><TD CLASS="quote">You have to use the bracket (the one that attaches to the engine block) from a 99-00 SI. I just did my swap not long ago and it went just fine. Hope that helps.</TD></TR></TABLE>
use 99-00 si/SiR or 96-01 CRV block mount both are the same.
94-01 integra block mount is different then most 92-00 civic block mounts (some 94-5 vx/si civics) used the same integra mount which is not compatiable
http://www.hondaautomotiveparts.com/home.htm
use the stock civic engine bracket from your sohc you currently have and remove the ls bracket....all 96-00 sivics uses the same drivers side engine mount design.so dont bother buying a 99-00 mount,on a swap like this into your 96-00 civic the only mount that is needed to work for any dohc swap is the 99-00 si mount for the rear....i hope this helps clear up alot of the false confusion.
yea i try that..............the ls engine bracket have three bolts on it and the civic as two and they don't line up.so that is where i am stuck at
i believe the part that connects to the ls block you need to order the 99-00 Si bracket but the hasport mount you have looks correct
good luck
good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm civic 2000 »</TD></TR><TR><TD CLASS="quote">use the stock civic engine bracket from your sohc you currently have and remove the ls bracket....all 96-00 sivics uses the same drivers side engine mount design.so dont bother buying a 99-00 mount,on a swap like this into your 96-00 civic the only mount that is needed to work for any dohc swap is the 99-00 si mount for the rear....i hope this helps clear up alot of the false confusion.</TD></TR></TABLE>
i was just gonna say that
i try to put the civic engine bracket on the ls motor..............but the ls have three bolts holding it to the motor and the civic have two.so then i just try to put the civic on by just putting in the two bolts but it doesn't line up to the holes already made on the engine
aight i bought the bracket today from honda for 50 bucks(discount).i have to wait b/c it had to be order.should have it in 2 days.thanks for the help on the problem i will keep u guyz posted
giovi_ek
Jun 6, 2015 06:19 PM
bori bori
10
Jan 8, 2010 11:05 AM
jDmImagE
Oct 15, 2005 01:18 PM
