mounting problem with ek swap
i have a 96 civic and i am swaping in a 96 ls motor...........i bought a mounting kit but the driver side mounts doesn't fit right.can anyone help i need my car done.i will post some pic soon asap
this is the bracket that is on the driver side.. ...size up to the mount bracket from the kit(holes doesn't line up) http://www.we-todd-did-racing.com/we...MXk1NDE%3D.jpg this is the bracket that is on the driver side http://www.we-todd-did-racing.com/we...MXk1NDE%3D.jpg this is the stock civic bracket with the new mounting bracket on it(it line up perfect) http://www.we-todd-did-racing.com/we...MXk1NDE%3D.jpg this is the 96 ls motor i will be using http://www.we-todd-did-racing.com/we...MXk1NDE%3D.jpg Modified by b16a1integra at 2:18 AM 8/8/2004 Modified by b16a1integra at 2:21 AM 8/8/2004 Modified by b16a1integra at 10:27 AM 8/8/2004 |
Re: mounting problem with ek swap (b16a1integra)
cant see shit just X's
Re: mounting problem with ek swap (ghettochild)
pics are up
nope not yet
they are now
I've done a swap on my cousin's civic hx with an b18b motor too. And we use just englarge the holes with a drill so it would fit. It was ghetto and my cousin was a cheap ass. Another one I did i use a 99-00 driver side mount and the side egine mount bracket and everything bolted right up, i think https://honda-tech.com/forums/images...s/emsmilep.gif Its been 3 years since I've done this swap. Which mounting kit did you get?
You have to use the bracket (the one that attaches to the engine block) from a 99-00 SI. I just did my swap not long ago and it went just fine. Hope that helps.
Re: mounting problem with ek swap (JoseCuervo)
i bought a hasport kit................the driver side engine bracket can be bought at honda???????or do they have a aftermarket one?????????and thanks for the help guys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JoseCuervo »</TD></TR><TR><TD CLASS="quote">You have to use the bracket (the one that attaches to the engine block) from a 99-00 SI. I just did my swap not long ago and it went just fine. Hope that helps.</TD></TR></TABLE>
https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: mounting problem with ek swap (Shaun)
use 99-00 si/SiR or 96-01 CRV block mount both are the same.
94-01 integra block mount is different then most 92-00 civic block mounts (some 94-5 vx/si civics) used the same integra mount which is not compatiable http://www.hondaautomotiveparts.com/...13S100_A07.gif http://www.hondaautomotiveparts.com/home.htm |
Re: mounting problem with ek swap (eg6ajk)
use the stock civic engine bracket from your sohc you currently have and remove the ls bracket....all 96-00 sivics uses the same drivers side engine mount design.so dont bother buying a 99-00 mount,on a swap like this into your 96-00 civic the only mount that is needed to work for any dohc swap is the 99-00 si mount for the rear....i hope this helps clear up alot of the false confusion.
Re: mounting problem with ek swap (jdm civic 2000)
yea i try that..............the ls engine bracket have three bolts on it and the civic as two and they don't line up.so that is where i am stuck at
i forgot about that its a 2 hole.wow now i dont know what i had done .now im confussed..get that si mount
i believe the part that connects to the ls block you need to order the 99-00 Si bracket but the hasport mount you have looks correct
good luck |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm civic 2000 »</TD></TR><TR><TD CLASS="quote">use the stock civic engine bracket from your sohc you currently have and remove the ls bracket....all 96-00 sivics uses the same drivers side engine mount design.so dont bother buying a 99-00 mount,on a swap like this into your 96-00 civic the only mount that is needed to work for any dohc swap is the 99-00 si mount for the rear....i hope this helps clear up alot of the false confusion.</TD></TR></TABLE>
https://honda-tech.com/forums/images/smilies/emthup.gif i was just gonna say that https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: mounting problem with ek swap (H22A EG6)
i told him that last night on here
i try to put the civic engine bracket on the ls motor..............but the ls have three bolts holding it to the motor and the civic have two.so then i just try to put the civic on by just putting in the two bolts but it doesn't line up to the holes already made on the engine
No u can't use ur stock SOHC civic engine bracket like stated above. You have to buy the 99-00SI DOHC Bracket
Re: mounting problem with ek swap (civicrtype)
aight i bought the bracket today from honda for 50 bucks(discount).i have to wait b/c it had to be order.should have it in 2 days.thanks for the help on the problem i will keep u guyz posted
