'00 B18C5 INTO A 94 CIVIC HATCH (4 ?'S)
Well I hope you swap guru's can answer these questions for me, I did a search and checked out the faq's with no luck...
1. Can I just plug up the connectors and thats it for the wiring? There's an extra plug with 3 wires on the passenger side of the engine that the civic doesn't have, whats that connection for and can I run without it?
2. Can I use the existing fuel system with the new engine, I will swap the fuel pump but can I use the civic's fuel filter. (I dont want to change it unless I have to because the inlet point is different and I would have to swap the whole line back to the fuel tank.)
3. How do I swap the brake line proportioning valve? I don't want to run abs, the civic's proportioning valve has 2 inlets 4 outlets, the R's prop valve has 2 inlets 2 outlets, what should I do?
4. Can I just swap the whole dash? the connectors are different (I think) where it plugs in, what are my options here?
any help is greatly appreaciated as these issues plague my thoughts, thanks in advance guys.
Chris
Chris
I put a 99 GSR B18C1 into my 94 EG hatch we just used the DX harness and put it on the GSR motor and added the extra wires for vtec and knock sensor... had to change the alternator plug from the obd1 plug to a obd2 plug and changed the distributor plugs from a obd2 plugs to obd1 plugs..never had a prob from fuel system
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR 1007 »</TD></TR><TR><TD CLASS="quote">
Yes, plug n' play
Yes, plug n' play
Signed Rick, who did just this
Yes, plug n' play
Yes, plug n' play
B18C5 EH
Aug 7, 2004 03:10 PM
