Oil line assembly, can anyone help?
I ordered an oil line kit from cheapturbolines.com and I'm curious how it actually goes together.
I have the 90degree turn going into the turbo and feed line, then the small brass adapter going from the feed line to the T, then the silver adapter going from the block to the T, then oil sender going to the back of the T. Is this correct?
'no idea what this is' is a SS bspt to npt thread adapter. Goes in the block where the oil pressure sender for the OEM dummy light is.
Thanks guys! Thats what I thought, but none of them wanted to screw in all the way, so i thought I better double check. As for the two similar large fittings, one goes into the drain flange for the turbo and one goes to the pan
MikeMAN
Jul 2, 2002 09:25 PM
