BIG PROBLEMS, HELP, SKIPPING BAD
Old Aug 6, 2004 | 07:36 PM
SPOOLINmatt's Avatar
Default BIG PROBLEMS, HELP, SKIPPING BAD
ok so im driving around today and its running alright still not boosting hardly and then i pull out with a friend and it just starts acting weird....no low end power at all...partial throttle is what i could do only...and if i just pressed it some more it would bogg out. I have a JRSC FMU on there and last night when i installed the turbo, the fuel pressure gauge was reading about 55 static psi and around 30 base. the car didnt do none of that skipping stuff. Now when i look at the gauge while the car is sitting there running...its running at 20psi...and when i take the line off to adjust the base pressure....it doesnt go up to 55 like it did....it just stays at 20. and i cant adjust it or nothing. The car idles alright but right when i tap that gas it just skips and studders like hell and it wont even go anywhere barely. i changed the spark plugs...and i took the jrsc fmu off and it still does it and sits on 20 psi and everything with the factory regulator. i checked and rechecked the map sensor and its hooked up fine and working and i took out the check valves to make sure of that too....this bitch just doesnt want to rev at all. and part of my boosting problem might be a little leak between the damn turbo flange and the manifold which is just great. any ideas.....im really thinking fuel pump but i just dont know.
Old Aug 7, 2004 | 09:10 AM
PodRacerSi's Avatar
Default Re: BIG PROBLEMS, HELP, SKIPPING BAD (arsenic57)
Almost have to be either the fuel pump, Or the pressure regulator.
Old Aug 7, 2004 | 10:06 AM
Default Re: BIG PROBLEMS, HELP, SKIPPING BAD (PodRacerSi)
thats what i was thinking because i have no fuel leaks so theres nothing else it could be, fuel system is very simple ya know.
Old Aug 7, 2004 | 01:37 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arsenic57 &raquo;</TD></TR><TR><TD CLASS="quote">.....im really thinking fuel pump but i just dont know.
There could be a restriction in the fuel system. Probably a bad fuel pump though.
Old Aug 7, 2004 | 02:01 PM
Boltz's Avatar
what are you using for a fuel pump(s)?
Old Aug 7, 2004 | 02:18 PM
Default Re: BIG PROBLEMS, HELP, SKIPPING BAD (Boltz)
factory 94 del sol pump
BoostinTEG
Engine Management and Tuning
Mar 8, 2011 05:43 AM
tegdude227
Oct 10, 2008 04:46 PM
vietxdragon
Aug 15, 2006 02:46 PM
SPOOLINmatt
Aug 6, 2004 07:35 PM
ludelvr
Nov 11, 2002 01:37 PM
