Has anyone used the 4inch e turbo?
I am thinking about getting this to pre spool my turbo and give me that added boost I need.
http://cgi.ebay.com/ebaymotors...33742
i've seen those things before and the same thoughts have gone through my head! you should buy it and tell us how it is!
that looks like a marine application blower fan.
at high rpm it is going to be nothing more than a restriction in the intake... it does not flow enough imo.
lol.
Modified by twkdCD595 at 11:27 AM 8/6/2004
lol.
Are people still falling for these scams?
260 CFM isn't even enough flow at 2000 RPM. Even if it was, these fans cannot produce any sort of boost. I could show you the mathematics involved, or you can just believe me that it takes nearly 2500 watts (4.5 hp) to produce 5 PSI of boost in an engine.
Nitrous would be your answer. If you could really get 30 hp from a dinky little fan, who would ever need a turbo. I'd just get bigger fans all day long. Maybe I would even string them together and create a twin/triple fan forced induction system!
Come on man, if you had the senses to go turbo, you should see right through this. that thing is a restriction to your system. try it yourself, it's been covered here on ht before tho i think.
http://www.boosthead.com/home.php
thomas knight web site... I think they are stupid but if someone were really looking at electric superchargers
A Thomas Knight electric charger works because it produces well over 3 kW. But it is still stupid, because the system weighs a ton, it isn't even closely comperable in boost output to a real turbo or supercharger, and you can only use it in short bursts.
Like nitrous. But heavy and 3x as expensive.
"MAKE IT STOP!"
