shifter was stuck in neutral
warmed the car up..went to stick it in reverse and it wouldnt move. the only direction it would go it was to first..any ideas? It works fine now. this has never happend before.
Guest
Posts: n/a
Get yur car up and see if the shft arm is bent. if not how long u have the car? mine does it time to time, when i stop at a light, then stick it into 1st i have to kinda release the clutch for it to go in all the way. i havent changed my clutch, but i know tats the problem wit the whole thing, and maybe for u too.
cool...the clutch is about due to be changed out..I am thinking too cause it was a cold night, but I dont know..I do get stuck in first often then I pump the clutch and it goes right in. cool thank you for your input..I was worried..
Ok peeps....Someone diagnose the problem here. 3 people have had the same problem I've had. I changed my clutch master and slave and the problem persists. I have pedal pressure, but wont go into a gear unless I turn off my car first.
226 to fix..new clutch and used clutch mast cylinder...wow...
good thing I have a few cousins in fontana...or my *** would be stuck in chino...I had driving my wife's car its a bitch mobile...
