M2B4 question, Avaialbility of parts etc....
I tried searching but could not find the answer I was looking for.
I know the casing is different on the M2B4 so you can't put a quaife or other LSD in it, so that got me thinking.
1. Will any H-series clutch kit work for the M2B4?
2. Other than the OEM LSD (tranny casing)what other things are different?
3. Can you put a quaife or other LSD in the M2A4?
Thanx for any replies....
1. any H series will work
2. that is about it
3. quaife or any afer market sd made for a H series
The only reason the oem lsd wont fit is because the lsd is too big. The after market LSDs are thiner so they fit
2. that is about it
By the way, just to make it completely clear, you also can not use an aftermarket LSD in an M2B4 tranny.
https://honda-tech.com/zerothread?id=930807
https://honda-tech.com/zerothread?id=780533
Well at least from one guy's actual experience, he couldn't get a quaife to fit. He's pretty well respected on this board as well.
