b18a/b questions?
Old Aug 5, 2004 | 04:18 AM
boost fed ls's Avatar
Default b18a/b questions?
I have searched but still have a few questions, I have a 01 integra ls, I am getting ready to buy a block and go from there. My question is is the b18a a pain in the *** to put into a 01 ls? I know the main diff. is sensor placement but is there any other diff that you know of(beside the head)? Can the b18a/b use the same pistons/rods and sleeves? Are the cranks the same? Will my ecu work with this block? Thanks!!!
Old Aug 5, 2004 | 05:31 AM
Honda Hick's Avatar
Default Re: b18a/b questions? (boost fed ls)
Yes, all the internals of the B18A/B are the same. There will be some sensor placement issues but you should be able to figure them out. You may need to get some adapters so take your time. The ECU would work with the block because it's the same bore/stroke/displacement, but you just have to figure out the sensors (ECU kinda needs them).
Old Aug 6, 2004 | 05:08 AM
Default Re: b18a/b questions? (Honda Hick)
thanks a lot
Old Aug 6, 2004 | 06:00 AM
3.504's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda Hick &raquo;</TD></TR><TR><TD CLASS="quote">Yes, all the internals of the B18A/B are the same. There will be some sensor placement issues but you should be able to figure them out. You may need to get some adapters so take your time. The ECU would work with the block because it's the same bore/stroke/displacement, but you just have to figure out the sensors (ECU kinda needs them).</TD></TR></TABLE>
what he said.
jdog_kustoms
Jan 27, 2015 05:52 PM
krazeenoy
Jun 10, 2007 06:24 PM
blackeg
Sep 8, 2005 06:48 PM
boost fed ls
Aug 10, 2004 07:40 AM
Ransom
Jul 29, 2003 05:10 PM
