b18a/b question
Old Aug 5, 2004 | 03:47 AM
boost fed ls's Avatar
Default b18a/b question
I have searched but still have a few questions, I have a 01 integra ls, I am getting ready to buy a block and go from there. My question is is the b18a a pain in the *** to put into a 01 ls? I know the main diff. is sensor placement but is there any other diff that you know of(beside the head)? Can the b18a/b use the same pistons/rods and sleeves? Are the cranks the same? Will my ecu work with this block? Thanks!!!
Old Aug 9, 2004 | 02:57 PM
B18Tahtaras's Avatar
Default Re: b18a/b question (boost fed ls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boost fed ls &raquo;</TD></TR><TR><TD CLASS="quote"> I have searched but still have a few questions, I have a 01 integra ls, I am getting ready to buy a block and go from there. My question is is the b18a a pain in the *** to put into a 01 ls? I know the main diff. is sensor placement but is there any other diff that you know of(beside the head)? Can the b18a/b use the same pistons/rods and sleeves? Are the cranks the same? Will my ecu work with this block? Thanks!!!</TD></TR></TABLE>
as far as the internals, sleeves, and ecu... yes they'll work. Its pretty much... plug and play as long as your state allows it for smog. it shouldnt be a pain in the *** any more so then replacing with an identical block.
Old Aug 9, 2004 | 04:49 PM
shawn_crx's Avatar
Why would you put a B18A in your car?
Plus If I remember you have to put the same year or newer engine only.
(state law)
Old Aug 10, 2004 | 05:21 AM
Default Re: b18a/b question (shawn_crx)
.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shawn_crx &raquo;</TD></TR><TR><TD CLASS="quote">Why would you put a B18A in your car?
(state law)</TD></TR></TABLE>
well the b18a block is the same as a b18b block(except for some sensor placement) so why would you pay an extra 200-400 extra just so it would say b18b. It's getting built with a b18b1 head. As for as against the law I think I have better things to worry about than not having the same year or newer block in my car, I think not having a cat is more of a fine than the motor issue. Plus if you would read my question, did you answer it ? so why post!
Old Aug 10, 2004 | 07:40 AM
mmuller's Avatar
Mad Scientist
the block itself its the same
jdog_kustoms
Jan 27, 2015 05:52 PM
allmotorek8
Apr 11, 2005 12:42 AM
JDM_Spec
Nov 25, 2004 10:45 AM
boost fed ls
Aug 6, 2004 06:00 AM
Triple T
Jan 27, 2003 04:10 PM
