What size are the speakers?
Very quick question, what size are the speakers front and back of a 98 integra? I'm going to buy new ones, I'm pretty sure its 6.5" but I just wnat to make sure, thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VizjereiAvatar »</TD></TR><TR><TD CLASS="quote">cool thanks
wanted to make sure and not waste a good 300$ on speakers!</TD></TR></TABLE>
But if you get any speaker with any real depth, you'll have to either cut the factory speaker backings, or fab new ones. I cut mine and used a foam backing to protect them in case water gets past the window seal. Also, my Infinity Kappas are large speakers, but they are about 1/4" from the window when down, so check your clearance carefully before you waste money.
wanted to make sure and not waste a good 300$ on speakers!</TD></TR></TABLE>But if you get any speaker with any real depth, you'll have to either cut the factory speaker backings, or fab new ones. I cut mine and used a foam backing to protect them in case water gets past the window seal. Also, my Infinity Kappas are large speakers, but they are about 1/4" from the window when down, so check your clearance carefully before you waste money.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IVI »</TD></TR><TR><TD CLASS="quote">my 4 door integra its a 6x9 </TD></TR></TABLE>
True, but only in the 4 door.
There are some people that have fabricated 6x9's behind that panel in the Integra Coupe. I'm sure if you search for the DIY thread, you can slap em on your car. 6x9's will improve the sound in a coupe BIG TIME>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnjoyTheRideDC2 »</TD></TR><TR><TD CLASS="quote">There are some people that have fabricated 6x9's behind that panel in the Integra Coupe. I'm sure if you search for the DIY thread, you can slap em on your car. 6x9's will improve the sound in a coupe BIG TIME>
6 1/2 separates will always sound better than 6x9s, especially when backed by a nice 10" or 12" in the trunk. A 6x9 will provide a little better mid bass, which I doubt is worth cutting the door metal to mount them, and is completely negated with a sub.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerN00b »</TD></TR><TR><TD CLASS="quote">
A 6x9 will provide a little better mid bass, which I doubt is worth cutting the door metal to mount them, and is completely negated with a sub.</TD></TR></TABLE>
I agree that its not worth cutting the door metal to fit 6x9's......but I was referring to the rear speakers. The rear panel area can be removed and 6x9's can be retrofitted. No door metal to cut.
i agree... just buy some nice door speakers and a little 10 or 12 for the back... i got one for sale if u want for real cheap... i suggest 'concept' speakers for the front... really high trebles if u have a sub
OneFire
Audio / Security / Video
11
Nov 3, 2008 12:56 PM
