Where to tap EGT probe on b-series Drag mani?
It should be on the 4th runner but the wastegate is placed there, which might make temps. inconsistent...so where should i tap it? thanks
ALSO...how far does the probe need to be away from the block? The auto-meter instructions suggest 4-6 inches but the 3rd runner is only like 3 inches long..where should i put it? thx
isn't 1-2 in" from the head too close? I'm just thinking that if you want to measure the gas temp and the head up of the block/head.. you could be 3-4? Just a tought (from the jet engine testing days)....
Lastly, what is the absolute temp to not exceed at which location.... I've read somewhere that I should see 1300 +/- 50 degF?? true?
thanks for the pic, but does anyone have a pic of the actual DRAG mani?? The runners are tiny and i really don't think there is a good spot to tap it where the probe won't be at an angle...doh
Who is Mr Robot?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by donkiman »</TD></TR><TR><TD CLASS="quote">numero tres and you should take it off to tap it.
i do believe that is #2, not 3, honda order goes (from the left) 4-3-2-1
</TD></TR></TABLE>i do believe that is #2, not 3, honda order goes (from the left) 4-3-2-1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost »</TD></TR><TR><TD CLASS="quote">
i do believe that is #2, not 3, honda order goes (from the left) 4-3-2-1</TD></TR></TABLE>
True but were not looking at the firing order here simply counting from left to right, right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboteg2nv »</TD></TR><TR><TD CLASS="quote">True but were not looking at the firing order here simply counting from left to right, right?
Starting from the timing belt in numerical order: Cylinder one, Cylinder two, Cylinder Three, Cylinder four. The picture you posted shows the EGT Probe in cylinder two.
Honda's firing order is 1,3,4,2. Cylinder one with camshafts pointing upwards or "0" degrees, cylinder 3 90 degrees counterclockwise, cylinder 4 180 degrees, and cylinder 2 270 degrees counterclockwise.
EDIT: INCORRECT FIRING ORDER *someone playing with my head?* Honda's firing order has always been 1342 on every four cylinder I've seen.
Modified by len at 3:56 PM 8/31/2004
Modified by len at 3:58 PM 8/31/2004
</TD></TR></TABLE>Starting from the timing belt in numerical order: Cylinder one, Cylinder two, Cylinder Three, Cylinder four. The picture you posted shows the EGT Probe in cylinder two.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboteg2nv »</TD></TR><TR><TD CLASS="quote">thanks for the pic, but does anyone have a pic of the actual DRAG mani?? The runners are tiny and i really don't think there is a good spot to tap it where the probe won't be at an angle...doh</TD></TR></TABLE>
my mani's drag gen4. there's enough space. the probe's from autometer egt gauge. mine's in 4th runner thuogh.
lol dudw i know. but as u can see the placement of the wg prevented me from using #3 so i had to use #2. but ya #3 is recomended. i just posted the pic cus its an up close pic of one installed.
sup ash?
do you think the 3rd runner has enough room to tap also? my EGT's on the way.
just curious - how come you didn't use drag the cold air extension on the air filter to locate it under the battery? that's where I put mine.
dood you got it all wrong # is the cly closest to the belts. so the distributor side is #4 and to whom ever said hondas firing order is 1234 no its 1243 look at yo dizzy...
[QUOTE=JTB]lol dudw i know. but as u can see the placement of the wg prevented me from using #3 so i had to use #2. but ya #3 is recomended. i just posted the pic cus its an up close pic of one installed.
jyacoba2009
Oct 4, 2009 05:07 PM
