timing belt walk
i just got the h22 accord together but i got the motor completly redone (8.4 to 1 comp. ratio) so i got new pistons, rods, water pump, oil pump, and all new seals. the only problem i got is the tming belt keeps walkin back against the block and i cant figure out how to get it to stop so i was hoping yall could help
There is a plate that goes on the crank before the crank sprocket. Was it installed?
This plate keeps the belt aligned and prevents rubbing on the block.
Another possibility is a bent or incorrectly installed belt tensioner.
91 b20 integra
Sep 22, 2014 08:44 AM
EGTeK
Aug 3, 2003 01:37 PM
