have a show in three days and cant remove climate control HELP!!!!!!!!!
ok how in the world and what in the world is holding in the climate control assembly in my integra its a 96 gs-r (their all the same just diff color) i know there are a few clips but are there any screws or bolts that i need to remove ??? please help!!!!
You have to remove the heater control cable under the passenger side of the dash. Then take out the warning light switch and the defost switch and there is a screw behind each one. The whole unit should come out then.
illl try that hopefully that works but right in that area is where its still holding so i thik your right thansk alot man
Once you have it popped out, you have to disconnect i think 2 plugs as well. If it doesnt come out easily, dont pull hard. Just check that temp cable underneath the passenger side dash and make sure its not getting caught on anything.
ner0x
Jun 23, 2005 07:17 PM
ITRITR
Apr 22, 2004 06:21 PM
