LS/Vtec Questions
Old Aug 4, 2004 | 08:32 AM
Merilious's Avatar
Default LS/Vtec Questions
I am planning on doing a LS/Vtec Setup in the near future, and I have some questions for people that have done it before.
I will be using a second gen JDM B16A Head, will there be any problems I would run into with matting it to the B18 block?
Can and If I use my P30 pistons in a B18B block, what conecting rods can/should I use?
What modifications, if any have to be made to the head gasket?
Any other info on this would be great, thanks.
Old Aug 4, 2004 | 08:44 AM
97L-esVeeTeg's Avatar
Default Re: LS/Vtec Questions (Merilious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Merilious &raquo;</TD></TR><TR><TD CLASS="quote">I am planning on doing a LS/Vtec Setup in the near future, and I have some questions for people that have done it before.
1. All vtec heads that are mated to non-vtec blocks have the same problem, need to drill and tap and run an external oil line.
2. p30 pistons are perfect, no mods to the stock LS rods needed, CR around 11.7 ish with b16 head
3. Run a stock LS head gasket.
Good Luck
Old Aug 4, 2004 | 08:57 AM
Merilious's Avatar
Sweet, thanks. I have another question now.
http://www.tornactive.com/pd_g...c.cfm
If I were to buy this LS/Vtec conversion kit, what fittings would I have to use?
Old Aug 4, 2004 | 09:03 AM
mmuller's Avatar
Mad Scientist
Default Re: (Merilious)
the kit comes with everything you need
Old Aug 5, 2004 | 06:32 AM
Merilious's Avatar
One more question for everyone.
I will be buying a header before I put the B18 block in. Will a B16A header work with a LS/Vtec setup? Will there be enough clearance for the longer block?
Old Aug 5, 2004 | 07:57 AM
LSVTEC 91 Civic's Avatar
Banned
I had to dent (and repaint) my oil pan in when I installed the ITR header, but not that much.
Old Aug 5, 2004 | 09:33 AM
Merilious's Avatar
So should I get a B18A1/B header or will any other one work without modding the oil pan.
Old Aug 5, 2004 | 10:49 AM
Merilious's Avatar
Old Aug 5, 2004 | 11:02 AM
vtecb20coupe's Avatar
B A N N E D
hmmm...good question about the header. i'm looking to buy one soon for my ls/vtec.
Old Aug 5, 2004 | 11:53 AM
Merilious's Avatar
Old Aug 9, 2004 | 12:07 PM
Merilious's Avatar
Another question I have is, is that I will be using P30 0.25 OS Pistons. But Golden Eagle doesnt make a 81.25mm bore LS/Vtec kit.
So I will have to buy the GE sandwich plate, fittings, dowel pins, and oil lines seperatly. Along with a LS head gasket from Acura. My question is this. Will I have to mod the head gasket in any way? Or does anyone know a place that has 81.25mm bore Golden Eagle LS/Vtec Kits?
Modified by Merilious at 9:54 PM 8/9/2004
Old Aug 9, 2004 | 12:59 PM
Merilious's Avatar
Anyone?
Old Aug 9, 2004 | 02:27 PM
Merilious's Avatar
ttt
Old Aug 9, 2004 | 02:48 PM
vtec69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Merilious &raquo;</TD></TR><TR><TD CLASS="quote">So should I get a B18A1/B header or will any other one work without modding the oil pan.</TD></TR></TABLE>
I used an JDM itr header with my ls/vtec and had no problems
i know lots of people just use a vtec header and dont have any problems
-Brian
turb0hatch04
Mar 5, 2007 11:13 AM
sleeperintegra
Apr 24, 2004 03:45 PM
Daniel_san
Sep 16, 2003 09:40 AM
Blanket Jackson
Sep 12, 2003 08:26 PM
