Will I need to Rip Apart my block for this??
part of the T that is attached to my block and the oil lines is stuck inside the block. my friend was taking it off for me and the T broke off, leaving stuck inside the block. we tried to get it out but no luck. will i have to tear down my block or is there a easier way?
Have you ever removed a broken bolt before?
Get the correct size easy out and use some gentle heat on the block around the threads. I don't think you will have to remove your engine...it will be tight to work in there but it is do-able.
is a easy out that tool you use to thread into it? if it is, we used one and part of that tool broke in there too. so in the block i have part of the T, and parrt of a tool, not sure what the tool name is though
easy outs will be your best friend, just be very careful, and clean the hole out well when your done. I don't know if you'll be able to get a drill down there, so you may need to remove the intake manifold
Now you have to drill the easy out out, and use another one. How the hell do you break an easy out? I have used them and beat on em pretty good, and it never broke on me.
