hanger trick with timing belt?
Old Aug 3, 2004 | 02:18 PM
99B16Si's Avatar
Default hanger trick with timing belt?
im having a problem getting a timing belt tight and ive heard a few people mention sticking a hanger down in the timing cover and yanking on the spring to get it to tension tighter. ive never had this problem before. can someone THOROUGHLY explain this to me please? thanks in advance
Old Aug 3, 2004 | 08:00 PM
99B16Si's Avatar
ttt
Old Aug 3, 2004 | 08:19 PM
Ryan C's Avatar
Default Re: (99B16Si)
worst comes to worst i would take the lower cover off and pry the tensioner up with a screwdriver.
Old Aug 3, 2004 | 08:56 PM
turbohondask's Avatar
Default Re: (Ryan C)
did you move the crank pulley 3 teeth counter clock wise then tighting the tensioner?
Old Aug 3, 2004 | 09:23 PM
Used2beAb16's Avatar
Default Re: (turbohondask)
I had the same problem with the tensioner, no matter how many teeth i turned it CC it never tensioned.
Its all in where u keep the slack on the belt
Old Aug 4, 2004 | 04:03 AM
limpy's Avatar
Default Re: (Used2beAb16)
this is how i do it.
unravel the hook end like you would when trying to break into your car after locking the keys in it. straighten out the hook and make a hook about 1/4 the size. then stick it bettween the cover and block and try and pull up on the lever that the spring is attached to on the tensioner. you can pull on the spring but sometimes you can pull it off the post if you do that then you have to take the timming belt cover off. when doing this make sure all of the slack is on the right side (intake side). hope this helped.
Old Aug 4, 2004 | 07:31 AM
99B16Si's Avatar
thanks limpy. i wasnt sure if i was supposed to actually pull the spring off the post, seemed kinda risky to me but its a last resort and if that doesnt work the timing cover has to come off anyway
does anyway know what causes this????
Old Aug 4, 2004 | 11:44 AM
ebelp's Avatar
Default Re: (limpy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by limpy &raquo;</TD></TR><TR><TD CLASS="quote">when doing this make sure all of the slack is on the right side (intake side). hope this helped.</TD></TR></TABLE>
How would you make sure the slack is on the intake side? Isn't the slack always on the exhaust side?
Old Aug 4, 2004 | 03:20 PM
limpy's Avatar
Default Re: (ebelp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebelp &raquo;</TD></TR><TR><TD CLASS="quote">
How would you make sure the slack is on the intake side? Isn't the slack always on the exhaust side?</TD></TR></TABLE>
get everything lined up and then turn the exhaust cam clock wise, then the intake and it will put all of the slack on the intake side of the motor.
Old Aug 4, 2004 | 03:25 PM
99B16Si's Avatar
tried the hanger trick and it worked like a charm. i accidently pulled the spring off the post but didnt have a problem getting it back on at all. thanks guys
Old Aug 4, 2004 | 08:04 PM
limpy's Avatar
your welcome... glad it helped.
tpnorth
20
Aug 8, 2011 11:13 AM
teler86
May 5, 2006 08:48 AM
IntegracinGSR
Aug 21, 2004 08:43 PM
integmester
Jul 2, 2004 05:38 PM
ranta18
Jul 9, 2003 12:41 PM
