check engine code 43........
Old Aug 3, 2004 | 08:56 AM
ensracer's Avatar
Default check engine code 43........
the book says fuel but i dont know what that means.......please help
Old Aug 3, 2004 | 09:40 AM
EE_Chris's Avatar
Default Re: check engine code 43........ (eduardo)
What car/engine/ECU/mods?
Typically a Code 43 is set when the Long Term Fuel Trim has reached its limit of either +/-20%. This value gets set from O2 sensor feedback.
Does that mean your O2 sensor is bad - No, well, not until you reveal your setup.
You could be running that rich/lean to set the code off; your O2 could be duffed; the wiring for the O2 could be duffed as well.
Old Aug 3, 2004 | 09:57 AM
ensracer's Avatar
Default Re: check engine code 43........ (EE_Chris)
its a 95 civic ex with an h22.........everything is completely stock
Old Aug 4, 2004 | 06:44 AM
ensracer's Avatar
so is it just the O2 sensor?
Old Aug 4, 2004 | 07:55 AM
EE_Chris's Avatar
Default Re: (eduardo)
Lets say your fuel injectors are a little more than clogged. This would mean that for the ECU to achieve the same a/f ratio, it has to keep the fuel injector open for a longer amount of time. The ECU 'sees' that it has to keep the injectors open for a longer period of time to get the O2 to do what its expects it to do (swing) - it does this via the Long Term/Short Term Fuel Trim.
So you see, in the above scenario, was the O2 the culprit? No, it sure wasn't - so I'm a little hesitant to say "replace your O2" when it could be anything that is restricting fuel flow/air flow and making the ECU adjust out of its operating range.
You say you're bone stock - how many miles are on the O2 sensor? Is it OEM - or Bosch garbage?
What about the rest of the engine maintenance - plugs/cap/rotor/wires and all that jazz?
avrfan
Aug 25, 2014 01:59 AM
civiccarbuff
Sep 18, 2008 08:29 PM
boostinh22
Nov 29, 2005 11:15 AM
96civich22
Feb 12, 2005 05:24 AM
Btothe3rdDegree
10
Jun 22, 2003 04:51 PM
