msd 2 step & msd module selector, same thing?
Old Aug 2, 2004 | 02:53 PM
torr's Avatar
Default msd 2 step & msd module selector, same thing?
wondering if the 2step is the same as the module selector. i know that the 2step takes individual pills and the selector has a wide range of settings but can the module selector be used as a 2 step by itself.
can you just plug in the module selector into the ignition rev limiter and have it work like a 2step?
Old Aug 4, 2004 | 08:08 AM
ms1motorsports's Avatar
Default Re: msd 2 step & msd module selector, same thing? (torr)
The module selector is just an RPM pill that can be adjusted to different settings. It works just the same a the standard RPM pill just has a dial on top to set different ranges. Just plug it into the 2step box and you'll be fine. The module selector is not a 2step by itself though.
90tegboosted
Engine Management and Tuning
May 24, 2013 04:31 PM
CIVICD16A9
Jul 4, 2005 08:26 AM
M.A.R.C.
Jun 20, 2004 02:56 PM
Specialblend27
Feb 17, 2003 09:46 AM
Rhetoric
Dec 16, 2001 12:05 PM
