B18 motor making noises wtf should I do
Old Aug 3, 2004 | 03:05 AM
mustninty's Avatar
Default B18 motor making noises wtf should I do
I got a gsr swap in my eg and it has been fine for a few years, but a few weeks ago it starting making a kind of clattering noise at any rpm, over 4 grand. It almost sounds like something is loose in the head. Is it safe for me to just pull the vavle cover off and start torqueing (to spec) everything in sight? Is there anything else I should check when I have the valve cover off? Could this be a sign of needed valve adjustment? Any assistance or ideas welcome.
Old Aug 3, 2004 | 03:36 AM
1.8turbolsvtec's Avatar
Default Re: B18 motor making noises wtf should I do (mustninty)
IM SENT
Old Aug 3, 2004 | 03:55 AM
mustninty's Avatar
Default Re: B18 motor making noises wtf should I do (1.8turbolsvtec)
I think IM's are blocked here at my job because I'm not getting it. I will either get it when I login at home or just post what you wanted to say.
Old Aug 3, 2004 | 04:26 AM
mosh666's Avatar
thats where i would start, hoping its not my rod bearings
Old Aug 3, 2004 | 12:28 PM
mustninty's Avatar
Default Re: B18 motor making noises wtf should I do (mosh666)
Dude still did not get your IM, and what are and how hard is it to change rod bearings if there toast?
Old Aug 3, 2004 | 01:00 PM
crx_88_si's Avatar
adjust valve lash maybe??
Old Aug 3, 2004 | 01:04 PM
BeerMan's Avatar
Default Re: B18 motor making noises wtf should I do (crx_88_si)
take off your oil pan and see if pieces of metal fall out
better hope you didn't spin a bearing, it would be a PITA for you, not to mention the cost
blasta510
17
Dec 19, 2011 11:17 AM
JDMEK9R
Mar 12, 2008 02:16 PM
vtecn8ive
Oct 6, 2006 07:14 PM
johnnycivic66
Nov 24, 2004 11:51 PM
danteisme
Feb 9, 2004 09:22 PM
