Spun Rod Bearing? Or just in need of Valve adjustment?
Spun Rod Bearing? Or just in need of Valve adjustment? w/video
http://www.youtube.com/watch?v=POUT1944HxU
The engine check like is not on or anything. What do you guys think.
Modified by JDMEK9R at 2:13 AM 1/13/2008
I cant really offer to much more insight. I checked my oil pan and found metal flakes in it. I believe low oil pressure was what got me, so now i'm rebuilding. Just get a few more opinions or pull it out and look for yourself if you have another means of transportation.
Re: Spun Rod Bearing? Or just in need of Valve adjustment? w/video (JDMEK9R)
also guys if i did spin a rod bearing, i wouldnt be able to drive my car right?
did you find out what it was? just curious. my car kind of sounds a little like that now even though its a brand spank'n new build. still trying to figure out if its just the pistons rattling.
the humm of your exhaust make it kind of hard to hear the noise very well so heres a few things to try.
does the noise get louder as the car heats up? - if so I would say spun rod bearing
does the noise go away when you push in your clutch pedal? - if so I would say main transmission bearing.
if neither of thoes then I would say do a valve adjustment like Dogginator said.
(its usualy a good idea to listen to what he has to say)
Im no expert but maybe that will help
mtkhalid
16
09-29-2008 10:47 PM
vtecn8ive
10-06-2006 07:14 PM
