Need Help guys, got a problem with my steering!!!!
Old Aug 2, 2004 | 05:45 PM
markeemarc's Avatar
Default Need Help guys, got a problem with my steering!!!!
all right, can anyone tell me whats wrong, i have a 94 civic hatch back and when ever i drive-the wheel jerks to the right and to the left, on its own, like i have to keep the steering wheel straight with two hands just so the car doesnt turn left or right, when ever i make turns it struggles to turn and makes clicking noise as well, if anyone can tell me what it is, any help would be appreciated...
Old Aug 2, 2004 | 06:48 PM
markeemarc's Avatar
Default Re: Need Help guys, got a problem with my steering!!!! (markeemarc)
anything will help guys- thanx
Old Aug 2, 2004 | 08:00 PM
RYAN_SJ's Avatar
Check the alignment angles. if car still has same problem and alignment is good put it on rack with its full wieght on the wheels and have someone turn the steering wheel back and forth while you check for worn or loose parts. Check cv joints for the clicking noises.
Old Aug 3, 2004 | 08:32 AM
markeemarc's Avatar
Default Re: Need Help guys, got a problem with my steering!!!! (RYAN_SJ)
thanks man, ill definitely do that tonight, i really appreciate your help
Old Aug 3, 2004 | 12:17 PM
IVI's Avatar
IVI
also check the tie rods.
Old Aug 3, 2004 | 04:07 PM
markeemarc's Avatar
Default Re: Need Help guys, got a problem with my steering!!!! (IVI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IVI &raquo;</TD></TR><TR><TD CLASS="quote">also check the tie rods.
will do man, thanks for your help!
Old Aug 4, 2004 | 06:55 AM
markeemarc's Avatar
man, i almost got into 6 accidents cause of this ****
Old Aug 4, 2004 | 07:22 AM
slateraptor's Avatar
Default Re: (markeemarc)
if your car is lowered and it jerks whenever you go over a bump, then the unexplained jerking is being caused by bump steer. take your car to an alignment shop and tell them to check if your toe is within spec.
Old Aug 4, 2004 | 12:22 PM
markeemarc's Avatar
Default Re: (slateraptor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slateraptor &raquo;</TD></TR><TR><TD CLASS="quote">if your car is lowered and it jerks whenever you go over a bump, then the unexplained jerking is being caused by bump steer. take your car to an alignment shop and tell them to check if your toe is within spec.</TD></TR></TABLE>
ok man, thanks for your help
huge230
Dec 15, 2009 07:51 PM
VTEC_Du_Ma_Mai
Suspension & Brakes
19
Feb 18, 2008 10:43 AM
92-95-04-06-civic
13
Feb 6, 2008 10:16 PM
rachonda
Jul 5, 2007 06:54 PM
94BlueGSR
Dec 2, 2006 10:07 AM
