Installing a strut bar?
Old Aug 2, 2004 | 04:42 PM
Tippolas's Avatar
Default Installing a strut bar?
I just bought an upper front strut bar for my 1995 Civic LX and was told it was very simple to install. Can anyone walk me through it with maybe some pictures?
Thanks
Modified by Tippolas at 9:13 PM 8/2/2004
Old Aug 2, 2004 | 04:47 PM
=GAME='s Avatar
Default Re: Installing a strut bar? (Tippolas)
what kind of strut bar? oem aftermarket? pop your hood, lay that bar across and it should be self explanatory
Old Aug 2, 2004 | 04:52 PM
Tippolas's Avatar
Default Re: Installing a strut bar? (=GAMEOVER=)
OBX strut bar. I'm like a huge noob
Old Aug 2, 2004 | 05:01 PM
00siALLmotor's Avatar
if u look at your engine bay, there are two bolts that hold your shocks down on each side.... remove those bolts...(total of 4...2 on each side) and place the strut bar...and bolt it back down... should be simple...good luck....
Old Aug 2, 2004 | 05:13 PM
Tippolas's Avatar
Default Re: Installing a strut bar? (00siALLmotor)
Honestly, I don't have the slightest clue as to where the shocks are located.
Modified by Tippolas at 10:04 PM 8/2/2004
Old Aug 2, 2004 | 05:56 PM
NewBorn_EG's Avatar
wow,learn more about your car before you start taking things apart.anyways you cant miss pretty easy to find
Old Aug 2, 2004 | 05:59 PM
hcivic99's Avatar
wow u dont diserve to even get a reply if u dont know where a shock is
Old Aug 2, 2004 | 06:01 PM
JamesQ's Avatar
Default Re: Installing a strut bar? (jdmEFnine1)
images taken from sleeper's car from the turbod forum.
the 2 bolts we're talking about. (already taken off in this picture)
gl with install
Old Aug 2, 2004 | 06:06 PM
Tippolas's Avatar
Default Re: Installing a strut bar? (JamesQ)
Cord, **** off. James, thanks a lot. I appreciate it.
Old Aug 2, 2004 | 06:08 PM
gabebauman's Avatar
dang...I always get beat to the punch oh well...here you go...
Your strut tower bar probably looks similar to the "silver bar" with gray ends going accross the top of the intake manifold, (if you know what that looks like). The gray ends attach to the two bolts sticking up through the fender well, (those are the shock bolts...2 on each side). Just unscrew all four of them...place the bar into position...then re-tighten the nuts...and you're done. I hope you can do this...because this is seriously the easiest mod other than a new oil cap.
Old Aug 2, 2004 | 06:18 PM
Tippolas's Avatar
Default Re: Installing a strut bar? (gabebauman)
Yea I just did it lol, thanks Gabe
MechEng
May 29, 2011 06:49 PM
rich_one1
Mar 23, 2011 04:11 PM
shawndb1
Mar 29, 2008 02:43 PM
dohcdelsol
Jun 1, 2004 06:06 PM
Bone Stock
May 4, 2004 12:30 AM
