different tire sizes for 15" wheel
Old 08-01-2004, 10:05 PM
ebp 99 si's Avatar
Default different tire sizes for 15" wheel
i'm buying another set of drag radials and i was wondering on which size to get
both are bfg g-force
225/50/15 or they just came out w/ 235/60/15
would the 235's fit on my rota wheels and not rub that much or would they be a bitch
ebp 99 si is offline
Old 08-02-2004, 08:20 AM
ebp 99 si's Avatar
Default Re: different tire sizes for 15" wheel (ebp 99 si)
bump
i need to find out today when i order my tires
Old 08-02-2004, 08:23 AM
sting94112's Avatar
the 235 60 15 is gonna be huge compared to the 225 50 15. its gonna be wider and taller
sting94112 is offline
Old 08-02-2004, 09:15 AM
huntarrr's Avatar
Default Re: different tire sizes for 15" wheel (sting94112)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sting94112 &raquo;</TD></TR><TR><TD CLASS="quote">the 235 60 15 is gonna be huge compared to the 225 50 15. its gonna be wider and taller </TD></TR></TABLE>
Thank you captain obvious!
What's your suspension setup?
huntarrr is offline
Old 08-02-2004, 10:23 AM
Sijray21's Avatar
Default Re: different tire sizes for 15" wheel (vsm98civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vsm98civic &raquo;</TD></TR><TR><TD CLASS="quote">
What's your suspension setup?</TD></TR></TABLE>
what he said,
wheels info too, like offset (spacers if your using any), and width
Sijray21 is offline
Old 08-02-2004, 10:26 AM
dantastic's Avatar
you should be able to squeeze the 235/60 on the the rim (assuming its atleast 6.5" wide) w/o any probs. but 235's wont tuck under your fenders
dantastic is offline
Old 08-02-2004, 01:14 PM
ebp 99 si's Avatar
Default Re: (dantastic)
hahaha yeah
the wheels are 15x6.5 rota slipstreams
my suspension is spax rsx full coilovers and stainless lines
the main reason for these tires is because i can't afford slicks right now and my turbosetup will be on the car in about a week or 2
Old 08-02-2004, 01:20 PM
electronb16si's Avatar
The car is going to have to be jacked up pretty high to get 235's under there. Also that is a gigantic tire to put on a 6.5in wide wheel. I would just go with 225 at the most. The 235 are gonna rub everywhere if you decide to turn the car very much at all.
electronb16si is offline
Old 08-02-2004, 01:28 PM
ebp 99 si's Avatar
Default Re: (electronb16si)
yeah
i have just decided to get the 225/50/15's
that way they wont' rub as much
Old 08-02-2004, 01:49 PM
-Trinitron-'s Avatar
you should be fine...I saw 255-50-15 on a 99-00 Si with the stock wheels at NOPI. I didn't realize it was possible. The guy said it rubbed when the wheel was turned almost all the way. I also can't find that tire size anywhere. I didn't notice what brand it was...just the enormous size!
If you want to get your calculator out and figure Tire Diameter, the only tire I have ever rubbed with was a 215-40-17 with a 1.75" drop. The 205-40-17 NEVER rubbed.
-Trinitron- is offline
Old 08-02-2004, 03:40 PM
ebp 99 si's Avatar
Default Re: (-TRINiTRON-)
i've seen a 255/50/16 drag radials but never a 15"
Old 08-02-2004, 04:00 PM
Sijray21's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -TRINiTRON- &raquo;</TD></TR><TR><TD CLASS="quote">you should be fine...I saw 255-50-15 on a 99-00 Si with the stock wheels at NOPI. I didn't realize it was possible. The guy said it rubbed when the wheel was turned almost all the way. I also can't find that tire size anywhere. I didn't notice what brand it was...just the enormous size!
If you want to get your calculator out and figure Tire Diameter, the only tire I have ever rubbed with was a 215-40-17 with a 1.75" drop. The 205-40-17 NEVER rubbed.</TD></TR></TABLE>
jesus...255/50/15's on an EM1 si....can't even imagine that, did it just go straight?
i have 205/50/15 azenis on my stock wheels, no spacers and it rubs when turned all the way in either direction, on the inside of the fenderwell...
Sijray21 is offline
Old 08-02-2004, 04:13 PM
I am sorry but 255 on stock wheels sounds like some BULLSHIT. I also had azenis on my 7" wide aguzzes and had a lot of rubbing issues. You could see where it rubbed all the paint off the inside of the fender where it rubbed everytime I made a U-turn or close to it. And correct me if I am wrong but aren't stock wheels only 6" wide? I don't see how it is possible to fit a 255 on that rim.
Old 08-02-2004, 06:21 PM
Sijray21's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by electronb16si &raquo;</TD></TR><TR><TD CLASS="quote">I am sorry but 255 on stock wheels sounds like some BULLSHIT. I also had azenis on my 7" wide aguzzes and had a lot of rubbing issues. You could see where it rubbed all the paint off the inside of the fender where it rubbed everytime I made a U-turn or close to it. And correct me if I am wrong but aren't stock wheels only 6" wide? I don't see how it is possible to fit a 255 on that rim.</TD></TR></TABLE>
completely agree, 255/50 on 6" wheel = impossible
Sijray21 is offline
Import Prelude
05-13-2007 04:28 PM
dmotoguy
11-18-2006 06:34 AM
Tim_Robbinz
07-21-2005 01:06 PM
Sound Streamin'
23
07-15-2004 06:47 AM
bearboy80
15
12-11-2003 10:07 AM
Quick Reply: different tire sizes for 15" wheel
  • Ask a Question
Question Title:
Description:
