cant get rid of code 22......
Code 22 for the vtec oil pressure sensor will not go away....Ive done everything wired vtec like 5 times (I know its right
) tryed grounding the sensor a few different ways tried multiple p28s and still code 22...Is it possible that the oil pressure sensor itself is just shot?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by japspecjohn »</TD></TR><TR><TD CLASS="quote">...Is it possible that the oil pressure sensor itself is just shot? </TD></TR></TABLE>
Yes, you can check it with an ohm meter.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca »</TD></TR><TR><TD CLASS="quote">Yes, you can check it with an ohm meter.</TD></TR></TABLE>
how do I do It?
how do I do It?
some body know how I do this? I got a multimeter
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by japspecjohn »</TD></TR><TR><TD CLASS="quote">bump need info dont wanna short out my ecu or sumthing
how do I do It?
It's a switch. It should be closed with the engine off and at idle. It should open as the RPMs increase.(as presure builds up)
how do I do It?
</TD></TR></TABLE>It's a switch. It should be closed with the engine off and at idle. It should open as the RPMs increase.(as presure builds up)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca »</TD></TR><TR><TD CLASS="quote">It's a switch. It should be closed with the engine off and at idle. It should open as the RPMs increase.(as presure builds up) </TD></TR></TABLE>
should i Test it where the wire meets the ecu?
same problem i have, ive rewired vtec at least twice, i have current and all my grounds are good. im just at a loss, sometimes the light will be off while im driving and then it will pop on at random times. im pretty sure the vtec actually works on my car... but still this code will not go away even after multiple ECU resets.
i was wondering if it could actually be a lack of oil pressure in my situation, because i know i have a valve cover gasket leak and im not sure how low my oil level has gotten. if it was actually low oil pressure, how would i go about diagnosing if i just need to change and fill up (along with replacing that gasket.. already have one im just lazy) or if there is an oil problem somewhere else?
sorry to jack ur thread, but its basically the same problem i have.
should i Test it where the wire meets the ecu?</TD></TR></TABLE>
Disconnect the wires to it and check the switch itself first.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MGXcoupe »</TD></TR><TR><TD CLASS="quote">
if it was actually low oil pressure, how would i go about diagnosing if </TD></TR></TABLE>
How do you diagnose a possible oil presure problem? Hook up an oil presure gauge.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pynikal »</TD></TR><TR><TD CLASS="quote">this might sound stupid but hows you oil level?? </TD></TR></TABLE>
it was fine it was the vtec oil pressure sensor (the bottom plug on the solinod) that was bad
bubs
Nov 30, 2005 09:43 AM
